Finding that one package that updated C++'s string library
Hi,
today I wanted to make some C++ code in Visual Studio Code and I got an "no != operator matches these operands" error when I try to compile the below code:
#include <iostream>
#include <string>
int main (int argc, char **argv)
    std::string str = "Hello";
    for(auto c : str) {} // <-- here is "error"
    return 0;
Although I came here to solve the problem in VSCode, I've found (after a lot of digging) that the problem may exist because something else outside VSC makes the program work wrong.
Here is what I've done:
  • reinstalled VSCode
  • the above + purge all configurations, installed extensions, etc. for VSC from my home directory
  • installed the VSC and the extension for C++ in older versions
nothing did the thing.
However I remember that not so long ago there was some package for the C++ language installed/upgraded in my system. Unfortunately I'm not able to recall both what it was called and when it was. My only clue is that it must has changed the "string" library for C++ somehow.
Of course I'm not sure about this trace, but I've to try it too to solve this puzzle. What I need is to find what package changed what file and when during installing/upgrading in the (aprox.) latest 10 days.
  Kernel: 6.3.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=6a135e81-5d37-4390-8a10-a9eef293c0d9 rw rootflags=subvol=@
    systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
  Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
    v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: Acer product: Aspire A515-54G v: V1.24
  Mobo: CML model: Doc_WC v: V1.24 serial: <superuser required> UEFI: Insyde
    v: 1.24 date: 07/07/2021
  ID-1: BAT1 charge: 37.9 Wh (100.0%) condition: 37.9/48.9 Wh (77.5%)
    volts: 16.2 min: 15.2 model: LGC AC14B8K type: Li-ion serial: <filter>
    status: full
  Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
    stepping: 0xC (12) microcode: 0xF6
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1612 high: 2100 min/max: 400/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2100 2: 2100 3: 800
    4: 800 5: 2100 6: 2100 7: 800 8: 2100 bogomips: 33599
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Acer Incorporated ALI
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Acer Incorporated ALI
    driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-05)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21
    bus-ID: 0000:02:00.0 chip-ID: 10de:1d13 class-ID: 0302
  Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: intel,nouveau
    unloaded: modesetting alternate: fbdev,nv,vesa dri: i965,nouveau gpu: i915
  Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x61ed built: 2018
    res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
  API: OpenGL v: 4.6 Mesa 23.1.1 renderer: Mesa Intel UHD Graphics (CML GT2)
    direct-render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Acer Incorporated ALI
    bus-ID: 0000:00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
  API: ALSA v: k6.3.5-zen1-1-zen status: kernel-api with: osspd status: off
    tools: N/A
  Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3 chip-ID: 8086:02f0 class-ID: 0280
    vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
    bus-ID: 0000:03:00.0 chip-ID: 10ec:8168 class-ID: 0200
    driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
    chip-ID: 8086:282a rev: class-ID: 0104
  Local Storage: total: 953.87 GiB used: 150.08 GiB (15.7%)
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B tech: SSD
    serial: <filter> fw-rev: 002C temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 476.38 GiB size: 476.38 GiB (100.00%)
    used: 150.03 GiB (31.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 54.6 MiB (56.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 476.38 GiB size: 476.38 GiB (100.00%)
  ID-4: /var/log raw-size: 476.38 GiB size: 476.38 GiB (100.00%)
  ID-5: /var/tmp raw-size: 476.38 GiB size: 476.38 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.58 GiB used: 1.94 GiB (25.5%)
  System Temperatures: cpu: 45.0 C pch: 48.0 C mobo: N/A gpu: nouveau
    temp: 41.0 C
  Processes: 284 Uptime: 9h 32m wakeups: 8 Memory: available: 7.58 GiB
  used: 2.79 GiB (36.8%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: dpkg
  pkgs: 0 pm: pacman pkgs: 1961 libs: 505 tools: pamac,paru Shell: Bash
  v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
  System install date:     2021-12-22
  Last full system update: 2023-06-01 ↻
I'd start digging into the pacman.log with some variance of
cat /var/log/pacman.log | grep '2023-05-30' | egrep 'installed|upgraded|removed'
Of course, you can choose more dates, but that would just make the list much longer, and in my opinion you necessarily have to evaluate those packages one by one, if necessary checking also their dependencies...
