File explorator dialog problem
Hello, since my first use of garuda linux I have this problem on software that open dialog windows with file explorer. I thing this is only for specific application that use particular technology (maybe java not sure). The picture speak itself :
I never found the source of this problem. Anyone could help me ?
Kernel: 6.9.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=f327471a-c329-462b-a1dc-fca7bb7580b2 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: LENOVO product: 20TH001AFR v: ThinkPad P1 Gen 3
Mobo: LENOVO model: 20TH001AFR v: SDK0T08861 WIN
serial: <superuser required> part-nu: LENOVO_MT_20TH_BU_Think_FM_ThinkPad
P1 Gen 3 uuid: <superuser required> UEFI: LENOVO v: N2VET26W (1.11 )
date: 11/16/2020
ID-1: BAT0 charge: 63.0 Wh (100.0%) condition: 63.0/80.4 Wh (78.4%)
volts: 17.2 min: 15.4 model: SMP 5B10X19049 type: Li-poly serial: <filter>
status: full cycles: 323
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
Info: model: Intel Core i9-10885H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2373 high: 3506 min/max: 800/5300 scaling:
driver: intel_pstate governor: powersave cores: 1: 3501 2: 2928 3: 800
4: 3500 5: 3240 6: 2983 7: 3499 8: 3019 9: 3500 10: 800 11: 3506 12: 3502
13: 800 14: 800 15: 800 16: 800 bogomips: 76800
Please, post full garuda-inxi log.
Which software / file explorer?
The picture dos not speak itself :wink:
Post also as text
locale
locale -a
The file explorer is a dialog window from “Bruno” application (similar to postman) when I want to search a forlder to open. This kind of window error is not only for this application. I don’t remember with apps make the error but it is not the first time.
Maibe someone have seen this problem already ?
date: 11/16/2020
volts: 17.1 min: 15.4 model: SMP 5B10X19049 type: Li-poly serial: <filter>
Speed (MHz): avg: 2499 high: 3559 min/max: 800/5300 scaling:
driver: intel_pstate governor: powersave cores: 1: 3501 2: 3555 3: 3544
4: 3500 5: 3500 6: 800 7: 800 8: 3504 9: 3496 10: 800 11: 800 12: 3533
13: 3507 14: 800 15: 800 16: 3559 bogomips: 76800
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-1,DP-2 empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1fb8
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b6cb
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915,nvidia d-rect: 5760x1080 display-ID: 0
Monitor-1: DP-1 pos: center res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-3: eDP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia wayland: drv: iris x11: drv: iris inactive: gbm,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1
device-ID: 8086:9bc4 memory: 15.12 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.1.1-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: Quadro T2000 with Max-Q Design driver: nvidia
v: 550.90.07 device-ID: 10de:1fb8 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
class-ID: 0401
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
API: ALSA v: k6.9.5-zen1-1-zen status: kernel-api tools: N/A
IF: wlp0s20f3 state: down mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.1:3 chip-ID: 0b95:1790
IF: enp44s0u1u1c2 state: up speed: 1000 Mbps duplex: half mac: <filter>
IF-ID-1: br-37f5839d7c04 state: down mac: <filter>
IF-ID-2: br-6b607d5a77cc state: down mac: <filter>
IF-ID-3: br-aa949aa60f01 state: down mac: <filter>
IF-ID-4: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-5: vethca6d394 state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 953.87 GiB used: 171.63 GiB (18.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
lanes: 4 tech: SSD serial: <filter> fw-rev: 5108AGLA temp: 51.9 C
ID-1: / raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
used: 171.6 GiB (29.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 33.6 MiB (13.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-4: /var/log raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.98 GiB used: 4.71 GiB (15.2%)
System Temperatures: cpu: 66.0 C pch: 73.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 3279 fan-2: 3116
Memory: total: 32 GiB note: est. available: 30.98 GiB
used: 15.42 GiB (49.8%)
Processes: 438 Power: uptime: 3h 16m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.35 GiB services: org_kde_powerdevil,
Packages: 1913 pm: pacman pkgs: 1891 libs: 526 tools: octopi,paru
pm: flatpak pkgs: 12 pm: snap pkgs: 10 Compilers: clang: 17.0.6 gcc: 14.1.1
Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.34
System install date:     2021-11-16
Last full system update: 2024-06-18 ↻
my local and local -a response
LANG=fr_FR.UTF-8
LC_CTYPE="fr_FR.UTF-8"
LC_NUMERIC=fr_FR.UTF-8
LC_TIME=fr_FR.UTF-8
LC_COLLATE="fr_FR.UTF-8"
LC_MONETARY=fr_FR.UTF-8
LC_MESSAGES="fr_FR.UTF-8"
LC_PAPER=fr_FR.UTF-8
LC_NAME=fr_FR.UTF-8
LC_ADDRESS=fr_FR.UTF-8
LC_TELEPHONE=fr_FR.UTF-8
LC_MEASUREMENT=fr_FR.UTF-8
LC_IDENTIFICATION=fr_FR.UTF-8
LC_ALL=
C
C.utf8
en_US.utf8
fr_FR.utf8
POSIX
Did you search about on developer page?
Github or Gitlab.
Only flatpak works.
Thank you for your link, I never found it, Indeed the packages that make this problem are install more often with snap.
