Hi, I have installed garuda a few days ago and I have few problems that i haven't managed to solve.
- I couldn't connect to wifi. After reading some posts on the forum, I have fixed it by installing
connman-git
. Now i can connect to wifi, but I can't still connect to 5GHz one. When I try to connect to it, I get:
Failed to toggle connection state.
GDBus.Error:net.connman.Error.NoCarrier: No carrier
- Garuda Network assistant won't open. When i try to open it using terminal, I get a dialog box with: "You must run this program as root.". And when I run with sudo, I get
Authorization required, but no authorization protocol specified
qt.qpa.xcb: could not connect to display :0
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
fish: Job 1, 'sudo garuda-network-assistant' terminated by signal SIGABRT (Abort)
The same problem is with garuda boot options
3. Set up assistant won't install anything. This isn't really an issue for me, but it is still an issue.
System specs:
System: Kernel: 5.14.5-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=24ad3743-e60c-43c5-bb58-f453d637d7ef rw rootflags=subvol=@ quiet splash
Desktop: sway 1.6.1 vt: 1 dm: N/A Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 82NW v: Legion 5 15ACH6A serial: <filter> Chassis:
type: 10 v: Legion 5 15ACH6A serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO v: G9CN09WW
date: 05/07/2021
Battery: ID-1: BAT0 charge: 20.9 Wh (25.0%) condition: 83.6/80.0 Wh (104.5%) volts: 14.9
min: 15.4 model: Celxpert L20C4PC1 type: Li-poly serial: <filter> status: Discharging
cycles: 6
CPU: Info: 6-Core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0 microcode: A50000C cache:
L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 79052
Speed: 2305 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz): 1: 2305
2: 1357 3: 2682 4: 2194 5: 2647 6: 2070 7: 2832 8: 1394 9: 3239 10: 2235 11: 1397
12: 1396
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP:
always-on, RSB filling
Graphics: Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Lenovo driver: amdgpu
v: kernel bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel bus-ID: 07:00.0
chip-ID: 1002:1638 class-ID: 0300
Display: wayland server: X.Org 1.21.1.2 compositor: sway v: 1.6.1 driver:
loaded: amdgpu note: n/a (using device driver) display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 165 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.5-zen2-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 07:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.14.5-zen2-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.35 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek vendor: Lenovo driver: rtw89_pci v: N/A modules: rtw89pci port: 2000
bus-ID: 06:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF: wlan0 state: up mac: <filter>
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 3-4:2
chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Drives: Local Storage: total: 953.87 GiB used: 12.63 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: 3L1QEXF7 temp: 40.9 C scheme: GPT
Partition: ID-1: / raw-size: 476.62 GiB size: 476.62 GiB (100.00%) used: 12.61 GiB (2.6%)
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.7 MiB (26.8%) fs: vfat
ID-3: /home raw-size: 476.62 GiB size: 476.62 GiB (100.00%) used: 12.61 GiB (2.6%)
ID-4: /var/log raw-size: 476.62 GiB size: 476.62 GiB (100.00%) used: 12.61 GiB (2.6%)
ID-5: /var/tmp raw-size: 476.62 GiB size: 476.62 GiB (100.00%) used: 12.61 GiB (2.6%)
ID-1: swap-1 type: zram size: 13.51 GiB used: 0 KiB (0.0%) priority: 100
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 344 Uptime: 1h 8m wakeups: 1 Memory: 13.51 GiB used: 2.28 GiB (16.8%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1143 lib: 306 Client: Unknown Client: garuda-assistant inxi: 3.3.06
