Fastfetch | garuda-fastfetch-git | Flashfest for Garuda Linux
Pimp your terminal/konsole :slight_smile:
New Version in
Old
Standalone executables
sudo cp fastfetch /usr/bin/
sudo cp flashfetch /usr/bin/
Download from
fastfetch/fastfetch · master · SGS / Wallpaper · GitLab
fastfetch/flashfetch · master · SGS / Wallpaper · GitLab
Source code
GitHub - sgse/fastfetch: Like neofetch, but much faster because written in C.
is a fork , kudos to
https://github.com/LinusDierheimer/fastfetch
We have this in repo now, called garuda-fastfetch-git :smiley:
My Details are not perfectly fitting using fastfech. and I also used
fastfetch -r
In above, some text are not fitting perfectly, can you guyz help me in that?
What you could try is editing fastfetchs config to output less stuff (it should be located in ~/.config/fastfetch/fastfetch.conf):face_with_raised_eyebrow:
What's the difference between flashfetch & fastfetch.
I tried to edit file ~/.config/fastfetch/config.cfg but it contains all lines with # tag. The text is,
# Fastfetch configuration
# Put arguments here to make them permanently (one per line).
# Direct arguments will overwrite the corresponding ones in this files
# Each line is whitespace trimmed on beginn and end.
# Empty lines or lines starting with # are ignored.
# There are more arguments possible than listed here, take a look at fastfetch --help!
# This version of the file was shipped with r118.16200fa.
# Use fastfetch --print-default-config > ~/.config/fastfetch/config.conf to generate a new one with current defaults.
How can I edit it?
Look in post #1 first picture.
Both are hardcoded, very small < 92 KiB.
Maybe use smaller font size.
Or fork my fork and edit to your liking.
fastfetch -h
fastfetch -l ubuntu
Larger terminal skin solves line break problem but still last 2 data is not aligned perfectly.
Yep, can confirm. Qtile
Wow, that's some broken jpeg right there, even though I seem to save it in PNG
New Year, new logos :smiley:
I accidentally deleted fastfetch in git, age does not pass me by without a trace :wink:
Newly created and supplemented with two logo variants.
fastfetch --list-logos
fastfetch -l garudadragon
fastfetch -l garuda
fastfetch
Just pushed to github.
You can remove the color palette with #Colors in
--structure Title:Separator:OS:Host:Kernel:Uptime:Packages:Shell:Resolution:DE:WM:WMTheme:Theme:Icons:Font:Cursor:Terminal:TerminalFont:GPU:Memory:Battery:LocalIP:OpenGL:OpenCL:Processes:Disk:CPUUsage:CPU
#Colors
There are many more modification options there. :slight_smile:
Just kitty :slight_smile:
So with the pictures I like it better than with the ascii stuff :smiley:
You bet!!! It’s like a totally different (much better) look.
Hey all,
I really like "the blue eagle", the second one in the picture above.
But i dont know how to have it in Konsole.
I tried this
╭─jacques@jacques in ~
╰─λ fastfetch --load-config garuda
Error: couldn't find config: garuda
But with no luck. Do i have to install something special ?
Or do you have a link to a wiki page for that ?
Here is the end of my config.fish
## Run fastfetch if session is interactive
if status --is-interactive && type -q fastfetch
   fastfetch --load-config dr460nized
end
Thanks in forward for your response.
Which Garuda DE are you using?
With i3wm it works only with Kitty, you can configure various, but also has weaknesses (copy and paste does not work with the mouse).
And you need the pictures and presets :slight_smile:
Hello,
I'm using Konsole in kde. Here's my inxi...
  Kernel: 6.2.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=5a2ed686-9f3f-4d1c-a51e-41bbeea7c18c
    rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
    loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.1 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
  Type: Convertible System: LENOVO product: 20FRS08T00 v: ThinkPad X1 Carbon 4th
    serial: <superuser required> Chassis: type: 31 serial: <superuser required>
  Mobo: LENOVO model: 20FRS08T00 v: SDK0J40697 WIN serial: <superuser required> UEFI: LENOVO
    v: N1FET80W (1.54 ) date: 07/29/2022
  ID-1: BAT0 charge: 46.8 Wh (100.0%) condition: 46.8/52.1 Wh (89.9%) volts: 17.1 min: 15.2
    model: SMP 00HW029 type: Li-poly serial: <filter> status: full
  Device-1: wacom_battery_0 model: Wacom Pen and multitouch sensor serial: N/A charge: 0%
    rechargeable: yes status: N/A
  Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake gen: core 6 level: v3
    note: check built: 2015 process: Intel 14nm family: 6 model-id: 0x4E (78) stepping: 3
    microcode: 0xF0
  Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 3201 high: 3207 min/max: 400/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3198 2: 3200 3: 3200 4: 3207 bogomips: 22399
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915 v: kernel arch: Gen-9
    process: Intel 14n built: 2015-16 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:5 chip-ID: 04f2:b531
  Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: LG Display 0x04aa built: 2015 res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2
    size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    direct-render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
  Sound API: ALSA v: k6.2.1-zen1-1-zen running: yes
  Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-7:4
    chip-ID: 8087:0a2b class-ID: e001
  Local Storage: total: 462.07 GiB used: 90.34 GiB (19.6%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 model: 00000 size: 238.5 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKGF240A5L size: 223.57 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: LV8i scheme: GPT
ID-1: / raw-size: 58.11 GiB size: 58.11 GiB (100.00%) used: 14 GiB (24.1%) fs: btrfs
    dev: /dev/sda6 maj-min: 8:6
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 612 KiB (0.1%) fs: vfat
    dev: /dev/sda5 maj-min: 8:5
  ID-3: /home raw-size: 58.11 GiB size: 58.11 GiB (100.00%) used: 14 GiB (24.1%) fs: btrfs
  ID-4: /var/log raw-size: 58.11 GiB size: 58.11 GiB (100.00%) used: 14 GiB (24.1%) fs: btrfs
  ID-5: /var/tmp raw-size: 58.11 GiB size: 58.11 GiB (100.00%) used: 14 GiB (24.1%) fs: btrfs
  ID-1: swap-1 type: zram size: 7.62 GiB used: 914.5 MiB (11.7%) priority: 100 dev: /dev/zram0
  System Temperatures: cpu: 55.0 C pch: 51.5 C mobo: N/A
  Fan Speeds (RPM): fan-1: 3452
  Processes: 243 Uptime: 7h 35m wakeups: 3 Memory: 7.62 GiB used: 5.93 GiB (77.9%) Init: systemd
  v: 253 default: graphical tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1334
  libs: 369 tools: octopi,paru Client: shell wrapper v: 5.1.16-release inxi: 3.3.25
Garuda (2.6.15-1):
  System install date:     2022-12-02
  Last full system update: 2023-02-28 ↻
Thats good. Work
for you?
We can edit the preset or add the garuda version and upload the picture.
