garuda-inxi output
ystem:
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=f559965d-1eb1-446e-89bc-3e0c13cc85ab rw [email protected]
resume=UUID=a579992a-65ed-4bf0-96a7-68ddd1fd3680 loglevel=3 ibt=off
Type: Laptop System: Dell product: Inspiron 5502 v: N/A
Mobo: Dell model: 0MTYV1 v: A00 serial: <superuser required> UEFI: Dell
v: 1.18.0 date: 09/12/2022
ID-1: BAT0 charge: 19.2 Wh (53.6%) condition: 35.8/53.0 Wh (67.5%)
volts: 16.2 min: 15.0 model: SWD-COS3.587 DELL 7T8CD0B type: Li-poly
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xA6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 902 high: 1271 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1072 2: 548 3: 663 4: 694
5: 1271 6: 1216 7: 1187 8: 567 bogomips: 27033
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Dell driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 bus-ID: 0000:2b:00.0 chip-ID: 10de:1d16
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:671b class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x23ed built: 2017 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:2c:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp44s0 state: up mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 0cf3:e007 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 29.77 GiB (6.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC711 NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 41002131 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 459.75 GiB size: 459.75 GiB (100.00%)
used: 29.77 GiB (6.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.75 GiB size: 459.75 GiB (100.00%)
ID-4: /var/log raw-size: 459.75 GiB size: 459.75 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.75 GiB size: 459.75 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.36 GiB used: 669.2 MiB (4.3%)
ID-2: swap-2 type: partition size: 16.89 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 63.0 C mobo: 61.0 C
Fan Speeds (RPM): cpu: 4979
Processes: 308 Uptime: 21m wakeups: 1551 Memory: 15.36 GiB
used: 9.76 GiB (63.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1259
libs: 315 tools: octopi,paru,yay Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-12-13
Last full system update: 2022-12-13
Sensors output
ath10k_hwmon-pci-2c00
Adapter: PCI adapter
temp1: +47.0°C
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +60.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +57.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +58.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +58.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +57.0°C (high = +100.0°C, crit = +100.0°C)
nvme-pci-e100
Composite: +44.9°C (low = -0.1°C, high = +82.8°C)
(crit = +84.8°C)
Sensor 1: +44.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +48.9°C (low = -273.1°C, high = +65261.8°C)
ucsi_source_psy_USBC000:001-isa-0000
in0: 5.00 V (min = +5.00 V, max = +5.00 V)
curr1: 0.00 A (max = +0.00 A)
dell_smm-isa-0000
fan1: 4975 RPM (min = 0 RPM, max = 4900 RPM)
temp1: +62.0°C
temp2: +62.0°C
temp3: +66.0°C
temp4: +60.0°C
temp5: +60.0°C
BAT0-acpi-0
Adapter: ACPI interface
in0: 16.19 V
curr1: 1.24 A
I am running VS Code with the Android Emulator, but after switching it off, the fan is still working.
After closing all the processes, I discovered that the memory was at 3 GB. What's the problem and why it is producing this much heat continuously . Please help me ,I am a beginner
