Farlight84 crash issue after system update
Hello Garuda users.
i was facing a problem to launchin farlight 84 game on steam but in i wlready played this game on this same system just some days ago idk what to do
command:
╭─alex@SoulHunter in ~
╰─λ garuda-inxi
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4ffdc21e-d8b6-4c1f-b1fb-883626b7e4ab rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: A320M-S2H v: N/A
Mobo: Gigabyte model: A320M-S2H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F53 date: 01/05/2021
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2813 high: 3692 min/max: 1600/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2954 2: 1654
3: 2953 4: 3692 bogomips: 27947
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 07:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 54.0 C
compositor: kwin_x11 driver: gpu: amdgpu display-ID: :0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: 24HC1QR serial: <filter>
built: 2020 res: 1920x1080 hz: 120 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 600mm (23.6") ratio: 16:9, 15:9
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 15.0.7 DRM 3.52 6.4.12-zen1-1-zen) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
vendor: Gigabyte driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168
Local Storage: total: 585 GiB used: 167.25 GiB (28.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT3500SC 6
CTB5029G21Y034 size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: A52B
ID-2: /dev/sdb maj-min: 8:16 model: SSD 128GB size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: XKR scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 29.87 GiB (25.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.59 GiB used: 3.58 GiB (26.4%)
System Temperatures: cpu: 54.5 C mobo: N/A gpu: amdgpu temp: 54.0 C
Processes: 339 Uptime: 3h 13m wakeups: 0 Memory: total: 16 GiB note: est.
available: 13.59 GiB used: 9.13 GiB (67.2%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1538 libs: 465 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-08-28
Last full system update: 2023-08-28 ↻
here you can find the logs of steam
please help me to fix it
This means that a reboot is pending after the latest update.
Most likely not related to your issue, but you never can say.
What was updated in the latest update? If you check the pacman logs you could try to understand if something important changed.
You could maybe test the linux-lts kernel.
Then select it at the next boot in the GRUB under Advanced Options.
nothing changes i booted with xanmod kernel and here is the logs
the problem is still exist.
