Fake 'no space left on device' error
I need help. And I think pictures can explain my situation better than my words.
The No space left on device error given by most of my applications is not true, and I cannot find a way to fix it.
Nope,
df -h
is enough as text. Pictures on technic help forums are never good. :slight_smile:
Nobody can read this blue text on your picture, sudo? Why sudo?
Where you got this error, no space left, more details, names ... ?
Try
Maybe a btrfs balance would help?
It shows an error:
ERROR: error during balancing '/': No space left on device
There may be more info in syslog - try dmesg | tail
Any good hint on that dmesg | tail ?
If not maybe you could try with some search on the Internet (although I'm usually reluctant on that), e.g.:
A btrfs scrub start / and btrfs balance / solve my problem. Thanks!
