I am unable to start Garuda Linux.
After booting up, it drops from the dragon circle thing to a black screen that says Failed to start Wait for Network to be Configured.
I'll take a picture and try to include it in my post.
New users cannot upload pictures. I'll type it out.
[ OK ] Started Adaptive readahead daemon.
[ OK ] Started Daemon that preven...utables/libraries from memory.
Started User Login Management
Started Virtual Machine a...tainer Registration Service...
Started UDisks2 managed ZRAM device zram0 setup...
[ OK ] Finished UDisks2 managed ZRAM device zram0 setup.
[ OK ] Finished Initialize hardware monitoring sensors.
[ OK ] Started Virtual Machine an...ontainer Registration Service.
[ OK ] Started User Login Management.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Bluetooth service.
[ OK ] Reached target Bluetooth Support.
[ OK ] Started Daemon for IPP over USB printer support.
Starting Hostname Service...
[ OK ] Started Hostname Service.
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting Network Wait Online...
[ OK ] Started Virtualization daemon.
Starting Permit User Sessions...
[ OK ] Finished Permit User Sessions.
Starting Deactivate Plymouth Boot Screen...
Starting Hold until boot process finishes up...
Starting Terminate Plymouth Boot Screen...
[FAILED] Failed to start Wait for Network to be Configured.
The only interaction I can perform on my computer when I reach this screen is Ctrl+Alt+Delete, holding my power button to power off the computer, and pressing my power button to power off.
I have tried using the fallback initramfs but it does the same thing.
the reflector command mentioned in the post you referenced is giving me warning after warning of being unable to rate downloads because the downloads are timing out after 5 seconds.
pacman produced an error about /sys/module/pcie_aspm/parameters/policy not being permitted to write
WARNING possibly missing firmware for module xhci_pci
same error message for aic94xx, wd719x, and xhci_pci
Do not post like in a chat room.
Please, no pictures from terminal output, so we use the no pictures from forum starter.
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
When I was exploring garuda assistant during the install process, I asked it to install proprietary drivers. I used timeshift to roll back the changes and returned to the Garuda login screen.
I apologize for being new and not knowing what to read first.
