Fail upgrading system
Hi, i tried to update my system with all the packages but I was facing too many errors of dependencies. The problem is that dependies are system dependencies (I deleted garuda-dr460nized, the theme of the OS trying to solve). Full output of the command here
 [🔍] × garuda-update
:: Sincronizando las bases de datos de los paquetes...
garuda está actualizado
core está actualizado
extra está actualizado
multilib está actualizado
chaotic-aur                             2,6 MiB  3,36 MiB/s 00:01 [------------------------------------] 100%
descargando garuda...
descargando core...
descargando extra...
descargando multilib...
descargando chaotic-aur...
:: Replace appstream-qt with extra/appstream-qt5? [Y/n] y
:: Replace attica with extra/attica5? [Y/n] y
:: Replace baloo with extra/baloo5? [Y/n] y
:: Replace bluez-qt with extra/bluez-qt5? [Y/n] y
:: Replace frameworkintegration with extra/frameworkintegration5? [Y/n] y
:: Replace kactivities with extra/kactivities5? [Y/n] y
:: Replace kactivities-stats with extra/kactivities-stats5? [Y/n] y
:: Replace karchive with extra/karchive5? [Y/n] y
:: Replace kauth with extra/kauth5? [Y/n] y
:: Replace kbookmarks with extra/kbookmarks5? [Y/n] y
:: Replace kcmutils with extra/kcmutils5? [Y/n] y
:: Replace kcodecs with extra/kcodecs5? [Y/n] y
:: Replace kcompletion with extra/kcompletion5? [Y/n] y
:: Replace kconfig with extra/kconfig5? [Y/n] y
:: Replace kconfigwidgets with extra/kconfigwidgets5? [Y/n] y
:: Replace kcontacts with extra/kcontacts5? [Y/n] y
:: Replace kcoreaddons with extra/kcoreaddons5? [Y/n] y
:: Replace kcrash with extra/kcrash5? [Y/n] y
:: Replace kdbusaddons with extra/kdbusaddons5? [Y/n] y
:: Replace kdeclarative with extra/kdeclarative5? [Y/n] y
:: Replace kded with extra/kded5? [Y/n] y
:: Replace kdesu with extra/kdesu5? [Y/n] y
:: Replace kdnssd with extra/kdnssd5? [Y/n] y
:: Replace kdsoap with extra/kdsoap-qt5? [Y/n] y
:: Replace kfilemetadata with extra/kfilemetadata5? [Y/n] y
:: Replace kglobalaccel with extra/kglobalaccel5? [Y/n] y
:: Replace kguiaddons with extra/kguiaddons5? [Y/n] y
:: Replace kholidays with extra/kholidays5? [Y/n] y
:: Replace ki18n with extra/ki18n5? [Y/n] y
:: Replace kiconthemes with extra/kiconthemes5? [Y/n] y
:: Replace kidletime with extra/kidletime5? [Y/n] y
:: Replace kimageformats with extra/kimageformats5? [Y/n] y
:: Replace kio with extra/kio5? [Y/n] y
:: Replace kirigami-addons with extra/kirigami-addons5? [Y/n] y
:: Replace kitemmodels with extra/kitemmodels5? [Y/n] y
:: Replace kitemviews with extra/kitemviews5? [Y/n] y
:: Replace kjobwidgets with extra/kjobwidgets5? [Y/n] y
:: Replace knewstuff with extra/knewstuff5? [Y/n] y
:: Replace knotifications with extra/knotifications5? [Y/n] y
:: Replace knotifyconfig with extra/knotifyconfig5? [Y/n] y
:: Replace kpackage with extra/kpackage5? [Y/n] y
:: Replace kparts with extra/kparts5? [Y/n] y
:: Replace kpeople with extra/kpeople5? [Y/n] y
:: Replace kpty with extra/kpty5? [Y/n] y
:: Replace kquickcharts with extra/kquickcharts5? [Y/n] y
:: Replace krunner with extra/krunner5? [Y/n] y
:: Replace kservice with extra/kservice5? [Y/n] y
:: Replace ktexteditor with extra/ktexteditor5? [Y/n] y
:: Replace ktextwidgets with extra/ktextwidgets5? [Y/n] y
:: Replace kunitconversion with extra/kunitconversion5? [Y/n] y
:: Replace kuserfeedback with extra/kuserfeedback5? [Y/n] y
:: Replace kwallet with extra/kwallet5? [Y/n] y
:: Replace kwayland with extra/kwayland5? [Y/n] y
:: Replace kwidgetsaddons with extra/kwidgetsaddons5? [Y/n] y
:: Replace kwindowsystem with extra/kwindowsystem5? [Y/n] y
:: Replace kxmlgui with extra/kxmlgui5? [Y/n] y
:: Replace libinput_gestures_qt with chaotic-aur/libinput-gestures-qt? [Y/n] y
:: Replace libkdcraw with extra/libkdcraw5? [Y/n] y
:: Replace libqaccessibilityclient with extra/libqaccessibilityclient-qt5? [Y/n] y
:: Replace mhwd-db-garuda-git with garuda/mhwd-db-garuda? [Y/n] y
:: Replace modemmanager-qt with extra/modemmanager-qt5? [Y/n] y
:: Replace networkmanager-qt with extra/networkmanager-qt5? [Y/n] y
:: Replace plasma-framework with extra/plasma-framework5? [Y/n] y
:: Replace prison with extra/prison5? [Y/n] y
:: Replace purpose with extra/purpose5? [Y/n] y
:: Replace qqc2-desktop-style with extra/qqc2-desktop-style5? [Y/n] y
:: Replace solid with extra/solid5? [Y/n] y
:: Replace sonnet with extra/sonnet5? [Y/n] y
:: Replace syndication with extra/syndication5? [Y/n] y
:: Replace syntax-highlighting with extra/syntax-highlighting5? [Y/n] y
:: Replace threadweaver with extra/threadweaver5? [Y/n] y
resolving dependencies...
:: removing kitemmodels breaks dependency 'kitemmodels' required by garuda-settings-manager
:: removing kauth breaks dependency 'kauth' required by garuda-settings-manager
:: removing kcoreaddons breaks dependency 'kcoreaddons' required by garuda-settings-manager
:: removing kcmutils breaks dependency 'kcmutils' required by garuda-settings-manager-kcm
:: removing kconfigwidgets breaks dependency 'kconfigwidgets' required by garuda-settings-manager-kcm
Thanks all for your time.
Your thread remains unnoticed because basic information is missing. Please stick to the instructions and try again.
You can edit your first post. Welcome to the Forum!
Welcome :slight_smile:
Without garuda-inxi this request will be moved to 412 Precondition Failed
