Hi, I installed GarudalLinux yesterday, this all working fine, but does not recognize my monitor connected by vga. Yesterday when I installed already with the monitor connected by vga the monitor was recognized and appeared in the display setting, but after turning off the pc, no longer worked and do not know why.
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 32767 x 32767
LVDS1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1366x768 60.00*+
1280x720 59.86 60.00 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
640x480 59.94
720x405 59.51 60.00 58.99
680x384 60.00
640x360 59.84 59.32 60.00
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Welcome to the forum
Can you provide your
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=10e4449d-0776-4705-8e73-504387bebbf1 rw rootflags=subvol=@
Desktop: Cinnamon v: 5.4.12 tk: GTK v: 3.24.34 wm: Mutter vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 24479E7 v: ThinkPad W530
Mobo: LENOVO model: 24479E7 serial: <superuser required> UEFI: LENOVO
v: G5ET94WW (2.54 ) date: 08/12/2013
ID-1: BAT0 charge: 51.3 Wh (98.7%) condition: 52.0/56.2 Wh (92.6%)
volts: 12.5 min: 10.8 model: LGC 45N1005 type: Li-ion serial: <filter>
status: charging
Info: model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1724 high: 3300 min/max: 1200/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 3300 3: 1197
4: 1200 bogomips: 20753
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
active: LVDS-1 empty: VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166
Device-2: NVIDIA GK107GLM [Quadro K1000M] vendor: Lenovo driver: N/A
alternate: nouveau non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:0ffc
Device-3: Acer ThinkPad Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-1.6:3 chip-ID: 5986:02d2 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: intel dri: i965
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: Seiko Epson 0x3152 built: 2010
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
Device-2: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
chip-ID: 8086:0085 class-ID: 0280
Local Storage: total: 259.93 GiB used: 13.94 GiB (5.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: 1231 size: 3.76 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT275MX300SSD1
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-1: / raw-size: 255.88 GiB size: 255.88 GiB (100.00%) used: 10.6 GiB
(4.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 255.88 GiB size: 255.88 GiB (100.00%) used: 10.6
GiB (4.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 255.88 GiB size: 255.88 GiB (100.00%) used: 10.6
ID-5: /var/tmp raw-size: 255.88 GiB size: 255.88 GiB (100.00%) used: 10.6
ID-1: swap-1 type: zram size: 7.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 237 Uptime: 1h 3m wakeups: 1 Memory: 7.58 GiB used: 2.72 GiB
(35.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1323 libs: 330
tools: gnome-software,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-10-30
Last full system update: 2022-10-31
TNE
October 31, 2022, 4:13pm
4
Does it work if you delete /etc/udev/rules.d/90-nvidia-prime-powermanagement.rules
and /etc/modprobe.d/nvidia-prime-powersaving.conf
and then reboot?
system
Closed
November 15, 2022, 5:56pm
6
