External Monitor not working after install of Spizaetus
My external monitor quit working after reinstalling system with latest Spizaetus iso. I had issue with prior iso as well but installing nvidia.dkms resolved the issue but installing after reinstalling system didn’t resolve this tiime. I have 2 physical disks in my system one with garuda and one with windows (external display works with windows)
[🔍] × garuda-inxi
  Kernel: 6.7.0-rc7-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
    root=UUID=adcc0028-d69b-47de-a69b-e580fa803db0 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
  Type: Laptop System: ASUSTeK product: ROG Strix G614JV_G614JV v: 1.0
  Mobo: ASUSTeK model: G614JV v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: G614JV.321 date: 10/24/2023
  ID-1: BAT0 charge: 82.7 Wh (99.0%) condition: 83.5/90.0 Wh (92.8%)
    power: 24.6 W volts: 16.5 min: 16.0 model: AS3GYFG3KC R220358 type: Unknown
  Info: model: 13th Gen Intel Core i9-13980HX bits: 64 type: MST AMCP
    microcode: 0x11D
  Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
    cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
    L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
  Speed (MHz): avg: 822 high: 1215 min/max: 800/5400:5600:4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 1023 4: 800
    5: 1215 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
    14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800
    23: 884 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800
    32: 800 bogomips: 154880
  Device-1: Intel Raptor Lake-S UHD Graphics vendor: ASUSTeK driver: i915
    v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 0000:00:02.0
    chip-ID: 8086:a788 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
    status: current (as of 2023-10) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ bus-ID: 0000:01:00.0
    chip-ID: 10de:28e0 class-ID: 0300
  Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 322e:2122
    class-ID: 0e02
  Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
    device-ID: 8086:a788 memory: 30.24 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.274 layers: 4 device: 0 type: integrated-gpu
    name: Intel Graphics (RPL-S) driver: mesa intel v: 23.3.2-arch1.2
    device-ID: 8086:a788 surfaces: xcb,xlib,wayland device: 1
    type: discrete-gpu name: NVIDIA GeForce RTX 4060 Laptop GPU driver: nvidia
    v: 545.29.06 device-ID: 10de:28e0 surfaces: xcb,xlib,wayland device: 2
    type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
    v: 23.3.2-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
  Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 0000:01:00.1 chip-ID: 10de:22be class-ID: 0403
  API: ALSA v: k6.7.0-rc7-1-mainline status: kernel-api tools: N/A
  Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 0000:00:14.3
    chip-ID: 8086:7a70 class-ID: 0280
    vendor: ASUSTeK driver: r8169 v: kernel port: 4000 bus-ID: 0000:6c:00.0
  IF: enp108s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0033
    rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
    class-ID: 0104
  Local Storage: total: 2.75 TiB used: 23.49 GiB (0.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P5PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 61.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Western Digital model: WD PC
    SN560 SDDPNQE-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 74104000 temp: 47.9 C scheme: GPT
  ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 23.46 GiB (23.5%)
    fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
    used: 22.8 MiB (2.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
    used: 23.46 GiB (23.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
  ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
  ID-1: swap-1 type: partition size: 34.07 GiB used: 0 KiB (0.0%)
  ID-2: swap-2 type: zram size: 30.97 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
  System Temperatures: cpu: 47.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Processes: 513 Uptime: 2h 17m wakeups: 1 Memory: total: 32 GiB note: est.
  available: 30.97 GiB used: 5.14 GiB (16.6%) Init: systemd v: 255
  pm: pacman pkgs: 1781 libs: 408 tools: octopi,pamac,paru pm: flatpak pkgs: 0
  Shell: Bash v: 5.2.21 running-in: kitty inxi: 3.3.31
Garuda (2.6.22-1):
  System install date:     2024-01-01
  Last full system update: 2024-01-01 ↻
 ╭─dabrown@rog1 in ~/Documents/restore took 3s
 ╰─λ sudo -i
[sudo] password for dabrown:
[root@rog1 ~]# garuda-inxi
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland dm: SDDM
  Mobo: ASUSTeK model: G614JV v: 1.0 serial: <filter> UEFI: American
  ID-1: BAT0 charge: 81.8 Wh (98.0%) condition: 83.5/90.0 Wh (92.8%)
    power: 28.3 W volts: 16.5 min: 16.0 model: AS3GYFG3KC R220358 type: Unknown
  Info: model: 13th Gen Intel Core i9-13980HX socket: U3E1 bits: 64
    type: MST AMCP arch: Raptor Lake gen: core 13 level: v3 note: check
    built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183)
    stepping: 1 microcode: 0x11D
  Speed (MHz): avg: 810 high: 982 min/max: 800/5400:5600:4000
    base/boost: 5049/8500 scaling: driver: intel_pstate governor: powersave
    volts: 1.4 V ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800
    6: 800 7: 915 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 982
    24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800 32: 842
    bogomips: 154880
    class-ID: 0e02
  Display: server: X.Org v: 23.2.3 with: Xwayland v: 23.2.3
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.00x12.52")
    s-diag: 599mm (23.6")
  Monitor-1: eDP-1 model: BOE Display NE160WUM-NX2 built: 2022
    res: 1920x1200 hz: 165 dpi: 143 gamma: 1.2 size: 340x210mm (13.39x8.27")
    diag: 407mm (16") ratio: 16:10 modes: 1920x1200
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
    device-ID: 8086:a788 surfaces: xcb,xlib device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 4060 Laptop GPU driver: nvidia v: 545.29.06
    device-ID: 10de:28e0 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
    (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM
  Server-1: PipeWire v: 1.0.0 status: n/a (root, process) with:
    class-ID: 0104
    lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 63.9 C
  SMART: yes health: PASSED on: 10 hrs cycles: 98
    read-units: 850,048 [435 GB] written-units: 802,405 [410 GB]
    fw-rev: 74104000 temp: 54.9 C scheme: GPT
  SMART: yes health: PASSED on: 32d 22h cycles: 172
    read-units: 3,526,378 [1.80 TB] written-units: 2,861,258 [1.46 TB]
    fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4 maj-min: 259:4
    used: 22.8 MiB (2.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
    used: 23.46 GiB (23.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4
    maj-min: 259:4
    maj-min: 259:4
    maj-min: 259:4
  System Temperatures: cpu: 49.0 C mobo: N/A
  Processes: 514 Uptime: 2h 18m wakeups: 1 Memory: total: 32 GiB note: est.
  available: 30.97 GiB used: 5.11 GiB (16.5%) igpu: 64 MiB Init: systemd
  v: 255 default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages:
  Shell: Bash (sudo) v: 5.2.21 running-in: kitty inxi: 3.3.31
Garuda (2.6.22-1):
  Windows dual boot:       Yes
The ‘swoosh’ indicates you first need to reboot since your update. Please do so then report back. Happy 2024. :slight_smile:
Try using x11 at login see if that resolves it
I am rebuilding my system and have rebooted may times. I just went upstairs rebooted with the monitor plugged into the HDMI and rebooted and still no external monitor.
I tried X11 and it worked but wayland used to work and wayland is my preferred . Looks like I have a work around till it can be fixed for wayland.
Maybe in wayland you could try the following kernel boot parameter:
nvidia-drm.modeset=1
With e.g.
sudo cp /etc/default/grub /etc/default/grub.bak && sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ nvidia-drm.modeset=1 "/g' -i /etc/default/grub && sudo update-grub
