Hi all, I've been using Garuda Linux on my laptop for about a week now with no issues, however a couple of days ago I ran into an issue where my external monitor started showing up as connected, but isn't displaying anything. I found that running xrandr --output HDMI-0 --mode 1920x1080 followed by xrandr --output HDMI-0 --mode 2560x1440 resolves this temporarily, but every time the display turns off, e.g. restart, sleep, or locking, I have to do this again. I don't encounter the issue on my Windows or Ubuntu partitions either. Any pointers on troubleshooting/resolving this would be greatly appreciated. inxi -Faz output:
This is telling that you’ve not been updating lately, since zen kernel is at 5.15.12 since the 29-Dec-2021. Although this is contrast with:
So, this was probably not due to an update.
On the contrary, if you installed something a couple of days ago, you could try restoring a previous snapshot.
Anyway, maybe you could update now, considering that in the meanwhile xorg-server was updated (you never can say, maybe this could help).
Apart from that, I don’t have experience in multi-monitor setups, but maybe I can pass you the two releant Arch Wiki articles. https://wiki.archlinux.org/title/Xrandr https://wiki.archlinux.org/title/Multihead
Hi Filo, thanks for the reply! Unfortunately updating didn't do the job. I looked over the documentation you linked and it prompted me to look over the xrandr output though, and there's some stuff that looks weird there.
Screen 0: minimum 8 x 8, current 4480 x 1440, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
2560x1440 144.00*+ 119.99 59.95
1920x1080 143.99 119.88 100.00 60.00 60.00 59.94 50.00 29.97 25.00 23.98
1680x1050 59.95
1600x1200 60.00
1600x900 60.00
1440x900 59.89
1400x1050 59.98
1280x1024 75.02 60.02
1280x960 60.00
1280x720 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
eDP-1-1 connected primary 1920x1080+2560+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 144.00*+ 60.01 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
1680x1050 (0x1ce) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1280x1024 (0x1d3) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1d4) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x960 (0x1d5) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1024x768 (0x1d8) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1d9) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x1da) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1dc) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x1db) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1dd) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x1de) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
640x480 (0x1e1) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1e3) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
My laptop screen's width seems to be getting picked up at 4480, which is actually my external monitor (2560) plus the laptop's actual width (1920). I'm not sure if this is expected, so if anyone else has any experience I'd greatly appreciate advice.
Update after investigating this more: the issue seems to be a combination of the refresh rate and the resolution. If I have my monitor set to 1440p@60hz it's able to display without issue, however at 120 or 144 it doesn't. If I change the refresh rate from 144/120 to 60 while the monitor is connected but not displaying, then revert the change, it works without issue though, in the same way changing the resolution does. This issue also doesn't occur when I've got it set to [email protected]. The reason this was working fine for the first week was because I was using the other HDMI cable plugged into my computer, which was only allowing up to 75hz. I've looked through a lot of similar reports on the Arch/Majaro forums and haven't found any solutions that work, or anything that is an actual match to this issue.
Hopefully there's enough info now for someone to have a better idea of what could be wrong - I've been trying to resolve this for over a week now and haven't made any headway.
