Expanding system partition
Hello, basically I didn't had plans to work on Linux based systems and only required it for some coding works. After a year of being on Linux- I don't boot into windows 99.9% of times. I originally have a 60 gb partition. I would like to expand it to 100 gb. I have 40 gb free space partition but I am not able to "resize" the garuda partition.
Maybe I am just not doing it the good way- Guidance please :grinning:
Essentially, boot the live installer environment and use GParted to extend the root partition.
Ok I'll try that in a moment
You cannot edit the partition you are currently using.
Therefore, you have to proceed as @Jonathon described, or you use a different partition, if one exists.
I am in live boot currently and still cannot. What now :thinking:
If you see a lock icon next to a partition, it means that partition is currently mounted and cannot be resized. To unmount it, just right-click on it and select Unmount. The lock should then disappear allowing you to modify the partition.
Nope no lock icon and it is already unmounted. Btw I am using the gnome-disks. Is gparted necessary?
To be honest I've always used GParted, I don't know much about Gnome-disks, but it should work in the same way.
Maybe you could give Gparted a try...
You know what- Gparted worked!
PS: For anyone booting with live boot- While trying to install Gparted from pacman -S command, it will try to update the whole system (1GB+). You can git clone and install it that way (aur packages basically), so it would only install Gparted thats it!
Thanks for the help guys :v:
Nice that you describe your solution. That can be very valuable for other users!
That's weird - pacman won't update packages unless you tell it to.
Also, if GParted isn't included by default (I thought it was) then it might be worth including.
Yep, gparted should be there!
Gparted is there in some versions, like in Cinnamon, XFCE, Mate etc. But not in dr460nized and some others.
It's not an affair at all, as long as you can install gparted with pacman or pamac.
