Everything about Chaotic-AUR packages
It didn't work for me.
the same here
it's not working, do I need a VPN?
It is fixed! Many thanks!
Can you double-check this for me? I think I found the root cause to this issue just a bit after you tried this (it's related to filenames having "db" in their name. Yes. I know, it's stupid.)
I am embarrassed to say I always speak before trying everything. the solution worked after re-installing garuda hopefully for the last time this year.
pasting this directly after installing and before garuda-update fixed the problem
thank you, you saved my life and my PC's hard drive.
I don't think you read the message above yours.
This issue has been fixed. Doing this is no longer necessary:
