Every window opens on secondary screen and cant close or resize any of them in fullscreen mode
Hello everyone,
I have an issue with opening windows on my Garuda Linux system. Every new window opens on my secondary monitor, regardless of where I initiate it from (even from the primary monitor). Furthermore, when a window is in fullscreen mode on the same secondary monitor, I am unable to minimize it, resize it, or close it. If anyone has a solution, I would be very grateful, as this problem is currently preventing me from effectively multitasking with my dual-monitor setup. And also here is the output from "garuda-inxi" below:
root=UUID=29b7f26e-eb8f-4efc-8960-10ab5a59a9bc rw [email protected]
resume=UUID=ade882a7-9c75-4f40-a5af-951e993f2799 loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING II v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4901
date: 07/25/2022
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3516 high: 3601 min/max: 2200/4467 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3500 2: 3500
3: 3500 4: 3601 5: 3500 6: 3500 7: 3599 8: 3500 9: 3500 10: 3500 11: 3500
12: 3500 bogomips: 83995
Device-1: AMD Tonga PRO [Radeon R9 285/380] vendor: PC Partner / Sapphire
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: DP-1,DVI-D-1 empty: DVI-D-2,HDMI-A-1 bus-ID: 07:00.0
chip-ID: 1002:6939 class-ID: 0300 temp: 58.0 C
Screen-1: 0 s-res: 4240x1440 s-dpi: 96 s-size: 1121x381mm (44.13x15.00")
s-diag: 1184mm (46.61")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: bottom-l model: Acer AL2216W
serial: <filter> built: 2006 res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2
size: 473x296mm (18.62x11.65") diag: 558mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
Monitor-2: DP-1 mapped: DisplayPort-0 pos: primary,top-right
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2022 res: 2560x1440
hz: 120 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x350
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon R9 380 Series (tonga
LLVM 15.0.7 DRM 3.49 6.2.13-zen-1-zen) direct-render: Yes
Device-1: AMD Tonga HDMI Audio [Radeon R9 285/380]
vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:aad8 class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Local Storage: total: 931.52 GiB used: 278.67 GiB (29.9%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Kingston model: SNVS500G
lanes: 4 type: SSD serial: <filter> rev: S8542105 temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
lanes: 4 type: SSD serial: <filter> rev: S8H40104 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 448.39 GiB size: 448.39 GiB (100.00%)
used: 278.64 GiB (62.1%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 25.8 MiB (8.6%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 448.39 GiB size: 448.39 GiB (100.00%)
ID-4: /var/log raw-size: 448.39 GiB size: 448.39 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.39 GiB size: 448.39 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3
ID-2: swap-2 type: zram size: 15.52 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 61.0 C mobo: 47.0 C gpu: amdgpu temp: 58.0 C
Fan Speeds (RPM): cpu: 2014 case-1: 1138 case-2: 1126 case-3: 1083
gpu: amdgpu fan: 553
Power: 12v: 10.03 5v: N/A 3.3v: N/A vbat: 3.27 gpu: amdgpu watts: 49.06
Processes: 318 Uptime: 1h 31m wakeups: 0 Memory: 15.52 GiB
used: 4.1 GiB (26.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 2071
libs: 566 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date:     2022-12-22
Last full system update: 2023-05-03
Failed units:            fancontrol.service
did you press F11 to exit full-screen?
No idea as I don't use KDE, but I found this old thread:
Applications starting up on the wrong screen. • KDE Community Forums
assuming it's not just the "allow apps to remember the position" thing, see the very last comment on page 2, the one with three links in it leading to GitHub - nclarius/KWin-window-positioning-scripts: KWin scripts controlling window placement on multi-monitor setups
yes i am, but it dosen't help at all...
aha I had a similar issue, I installed Garuda full edition, those windows
if you a refering to, they just have hidden the title bar - well if you mean that,
this is a feature among other anoying features of that release.
So I did not want to go , again through all of them, I just took the
lite zen version of Garuda. I just do not remember the name of that
component as used for optical enhancments, which they ar not but just anoying.
( i mean the dr4gonized) edition. Also could help if the .config, .local folder
would be deleted.
