MWM
November 7, 2022, 4:46am
1
I recently moved my computer to a different room and understandably have been connecting it to a different Ethernet port then before. This Ethernet port is very spotty, sometimes doesn't work entirely or flickers on and on. I connected a windows machine to the same ethernet port and had no issues. On the ethernet in the room I used to be in I never had even a slight performance drop. The ethernet I am attempting to use is going through a ZyXEL network switch if that makes any difference
I appreciate any and all help!
Thank you in advance!
What matters is.... We need a garuda-inxi report so someone can potentially help you. That will provide us details on what Ethernet NIC you actually have as a starting point.
MWM
November 7, 2022, 5:38am
3
here is the text spat out by garuda-inxi
I hope this helps!
Kernel: 6.0.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2
root=UUID=89ad8e2d-f58a-4724-9502-dbdbfbe73c11 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3001
date: 12/04/2020
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3998 high: 4002 min/max: 2200/5980 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4000 2: 3998
3: 4000 4: 3998 5: 4000 6: 3982 7: 4000 8: 3997 9: 3998 10: 3999 11: 4000
12: 4000 13: 4000 14: 3999 15: 4000 16: 4000 17: 3999 18: 4000 19: 4000
20: 4000 21: 3997 22: 3997 23: 3996 24: 4000 25: 4000 26: 4000 27: 4000
28: 4002 29: 4000 30: 4000 31: 4000 32: 3999 bogomips: 256023
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 4
link-max: lanes: 16 bus-ID: 03:00.0 chip-ID: 10de:1f08 class-ID: 0300
s-diag: 610mm (24")
Monitor-1: DP-0 res: 1920x1080 dpi: 92 size: 532x304mm (20.94x11.97")
diag: 613mm (24.12") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 03:00.1 chip-ID: 10de:10f9 class-ID: 0403
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.0.7-zen1-1-zen running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2526 class-ID: 0280
lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
v: 0.8 bus-ID: 5-5:2 chip-ID: 8087:0025 class-ID: e001
address: <filter>
Local Storage: total: 1.82 TiB used: 537.48 GiB (28.9%)
model: WDS200T2B0A-00SM50 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 537.48 GiB
(28.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 537.48 GiB
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 537.48
GiB (28.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 537.48
ID-1: swap-1 type: zram size: 62.71 GiB used: 95.2 MiB (0.1%)
System Temperatures: cpu: 53.6 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
Processes: 517 Uptime: 2h 1m wakeups: 0 Memory: 62.71 GiB used: 7.89 GiB
(12.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1997 pm: pacman pkgs: 1985
libs: 550 tools: octopi,paru pm: flatpak pkgs: 12 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-10-17
Last full system update: 2022-11-06 ↻
You MIGHT be a good candidate to try the r8168 driver (package r8168), or the r8168-dkms (from chaotic-aur), which it what I use myself.
[SOLVED] Problem with Realtek 8111/8168/8411 | No internet | r8169 / Kernel & Hardware / Arch Linux Forums is one reference to it, including the manual blacklist if need-be, but doesn't include the r8168-dkms which works with more kernels, including one you seem to be using as well, linux-zen, so, yes.
pacman -S r8168-dkms
might solve your problem.
tbg
November 7, 2022, 7:28pm
5
90% of Ethernet performance problems are related to cabling.
Windows will often be problem free, while Linux can have issues with the same network cabling. I would highly suggest purchasing some cat 6e or cat 7e cabling to make sure cabling is not part of the issue.
MWM
November 9, 2022, 4:51am
6
so it would be the cableing from the router to the network switch if I understand you correctly?
MWM
November 9, 2022, 4:52am
7
I installed the r8168-dkms driver and the issue persisted
Thank you for the help though!
