Esc and Q keys stop working
Hey everyone!
Been having quite a few issues with my garuda hence why i'm postinga bit regularly here for help. Now the situation is as follows randomly, my 'Q' and 'Esc' keys stop working. Before I never had an Issue, and i'm not that confident it's a hardware issue as 2 weeks ago before I switched to linux I never had an issue with it in Windows. I've tried searching for similar cases but cant find any this similar.
Sometimes they only work when I'm pressing another key, some other times they just don't work, and other times, like now, they work flawlessly. When they're not working, xev doesn't detect them at all. Any tips on how to fix this?
Here is my garuda-inxi:
  Kernel: 6.4.11-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    root=UUID=8b5dad39-7bad-4f79-8a48-361ffb45159c rw rootflags=subvol=@
    resume=UUID=a6f142fa-98ba-4663-8088-23273caf01e8 loglevel=3 ibt=off
  Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
    v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401QM_GA401QM
  Mobo: ASUSTeK model: GA401QM v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: GA401QM.412 date: 08/30/2022
  ID-1: BAT0 charge: 42.4 Wh (75.2%) condition: 56.4/76.0 Wh (74.2%)
    power: 25.8 W volts: 15.8 min: 15.8 model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A status: discharging
  Info: model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA50000C
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1462 high: 3300 min/max: 1200/4679 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 3300
    3: 1200 4: 1198 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200
    12: 1200 13: 3300 14: 1200 15: 1200 16: 1200 bogomips: 105407
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-08) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 48.0 C
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu,nvidia
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 583mm (22.95")
  Monitor-1: eDP-1 mapped: eDP-1-0 model: Sharp LQ140M1JW49 built: 2020
    res: 1920x1080 hz: 144 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
    diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce RTX 3060
    Laptop GPU/PCIe/SSE2 direct-render: Yes
  Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
  API: ALSA v: k6.4.11-zen2-1-zen status: kernel-api with: aoss
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7961 class-ID: 0280
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:3563
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 476.94 GiB used: 260.86 GiB (54.7%)
    fw-rev: FXM7201Q temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 460.11 GiB size: 460.11 GiB (100.00%)
    used: 260.86 GiB (56.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 460.11 GiB size: 460.11 GiB (100.00%)
  ID-4: /var/log raw-size: 460.11 GiB size: 460.11 GiB (100.00%)
  ID-5: /var/tmp raw-size: 460.11 GiB size: 460.11 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.53 GiB used: 0 KiB (0.0%)
  ID-2: swap-2 type: zram size: 15.03 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 58.9 C mobo: N/A
  Fan Speeds (rpm): cpu: 2900
  GPU: device: nvidia screen: :0.0 temp: 46 C device: amdgpu temp: 49.0 C
  Processes: 388 Uptime: 22m wakeups: 2 Memory: total: 16 GiB note: est.
  available: 15.03 GiB used: 3.99 GiB (26.6%) Init: systemd v: 254
  pm: pacman pkgs: 1602 libs: 505 tools: pamac,paru Shell: fish v: 3.6.1
  default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.29
  System install date:     2023-08-03
  Last full system update: 2023-08-20 ↻
Have you tried booting from a live USB to see if you get the same behaviour?
Are you plugged into a USB hub? I’ve been facing some similar issues with my bluetooth dongle lately (also on a hub), so maybe they just introduced some usb hub breaking change?
I am using one for ethernet! However i'm using the integrated keyboard on my laptop currently as I'm not home for a while. When I was using my external kb, I was plugging it to the monitor hub which connects through a usb-c directly to the pc and I didn't have this issue back then.
Right now I can't test with the external kb though.
I'll try that and post the results later
