Hello Naman , thanks for the fast answer , really appreciated.
Well , its an old lap top around 6-7 yrs so we can say that is hdd pretty old too.
But the strange thing is that its behaviour is normal , even the installer went very good. I also did backup of around 500-600gb on very same hdd without a single error.
Heres the system information:
System: Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=675f8ed4-9663-42b9-a6cb-454679e09ffe rw [email protected] quiet splash
Desktop: N/A vt: 1 dm: N/A Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: X556UB v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X556UB v: 1.0 serial: <filter> UEFI: American Megatrends
v: X556UB.411 date: 01/24/2019
Battery: ID-1: BAT0 charge: 14.1 Wh (100.0%) condition: 14.1/38.0 Wh (37.1%) volts: 7.6
min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
cycles: 1027
Device-1: hidpp_battery_0 model: Logitech M310 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 4E (78) stepping: 3 microcode: E2 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19200
Speed: 2701 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 2701 2: 2786 3: 2717
4: 2271
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940M] vendor: ASUSTeK driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:1347 class-ID: 0302
Device-3: Realtek USB Camera type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 0bda:57b5 class-ID: 0e02 serial: <filter>
Display: wayland server: X.Org 1.21.1.1 compositor: wayfire driver: loaded: nouveau
note: n/a (using device driver) display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-zen2-1-zen running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: no
Sound Server-5: PipeWire v: 0.3.27 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: d000 bus-ID: 03:00.0
chip-ID: 168c:0036 class-ID: 0280
IF: wlan0 state: up mac: <filter>
Bluetooth: Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:6
chip-ID: 13d3:3490 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Drives: Local Storage: total: 931.51 GiB used: 6.43 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
Partition: ID-1: / raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 6.42 GiB (16.4%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 1001 MiB size: 999 MiB (99.80%) used: 560 KiB (0.1%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 35.47 GiB size: 35.47 GiB (100.00%) used: 10.3 MiB (0.0%)
fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 6.42 GiB (16.4%)
ID-5: /var/tmp raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 6.42 GiB (16.4%)
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
ID-2: swap-2 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767
ID-3: swap-3 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
Sensors: System Temperatures: cpu: 37.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2400
Info: Processes: 225 Uptime: 6m wakeups: 5 Memory: 7.63 GiB used: 1.18 GiB (15.5%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
pacman: 1123 lib: 291 Shell: fish v: 3.2.1 default: Zsh v: 5.8 running-in: alacritty
inxi: 3.3.04
Thanks , i might hang around regardless of problems.
Update2: I did some playing in BIOS , secure boot / fast boot settings disabling/enabling and so on ..
I did get some progress , in this case , sometimes it boots , sometimes it doesnt. Could it be an BIOS issue ? In this case i managed to boot Garuda with secure boot off , fast boot off , smart hdd scan off.
Same error repeated few times but again it switched back to hdd0 , when error appears i restart the lap top and its gone , sometimes it boots , sometimes it doesnt. Funny
update3: as we speak when i shutdown completely and turn on error appears, then i shut down again and turn on, the error is magically gone. What the..
Hi,, he mean ~~~ not 3 ~
greetings, SGS
Oooops sorryz, didnt use forums for ages.
