Error: grub_is_shim_lock_enabled , prevents me from using my portable linux m.2 drive on any computer
Hello Garuda users.
I know that this error appears to prevent unauthorized users from booting your Linux drive on any computer other than yours!
the goal I want to reach is :
How to make my external m.2 Linux run on any computer, Just plug and run!!!
Loading Linux Linux-zen...
error: symbol `grub_is_shim_lock_enabled` not found
Loading initial ramdisk
press any key to continue
don’t recommend me to do live-boot iso from a USB stick and then do chroot to do:
grub-install --disable-shim-lock
also tried :
to install refind and all those help me in rebooting on the main computer, but I want my external m.2 Linux to be directly bootable on any computer (not just mine)!
also, the errors are regenerated when unplugging my external m.2 Linux from the main machine, It requires me to do chroot reapply refind-install, and change the priority boot drive in bios, such a pain!
Push to Unsupported Software (AUR & Other) from Garuda Community.
So you are missing the template.
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
