Haven’t been able to update for a few days cause of this error.
:: installing boost-libs (1.86.0-1) breaks dependency 'libboost_context.so=1.83.0-64' required by suyu-dev-qt6-git
Kernel: 6.10.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=82f4f668-10d7-4b04-9701-198a8ae3e43b rw rootflags=subvol=@
resume=UUID=f4a34052-d3e1-450e-9f98-2fe3749629df loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop System: Micro-Star product: MS-7B61 v: 1.0
Mobo: Micro-Star model: Z370 GAMING PLUS (MS-7B61) v: 1.0
UEFI: American Megatrends v: 1.A0 date: 06/08/2020
Device-1: hidpp_battery_0 model: Logitech G502 X LIGHTSPEED serial: <filter>
charge: 87% rechargeable: yes status: discharging
Info: model: Intel Core i5-9600KF bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x100
desc: 1x9 MiB
Speed (MHz): avg: 4482 high: 4508 min/max: 800/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 4500 2: 4501 3: 4500
4: 4508 5: 4400 6: 4485 bogomips: 44398
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
off: DP-1,DP-2,HDMI-A-1 empty: HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:2504
Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11.3:21
chip-ID: 1532:0e03 class-ID: 0102
Device-3: HTC (High Tech ) Vive driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.1.2:13
chip-ID: 0bb4:2c87 class-ID: 0102
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
Screen-1: 0 s-res: 3840x1080 s-dpi: 94 s-size: 1038x292mm (40.87x11.50")
s-diag: 1078mm (42.45")
Monitor-1: DP-2 pos: primary,right res: 1920x1080 dpi: 93
Monitor-2: HDMI-0 pos: left res: 1920x1080 hz: 60 dpi: 96
size: 510x287mm (20.08x11.3") diag: 585mm (23.04") modes: N/A
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
memory: 11.72 GiB
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 560.35.03
device-ID: 10de:2504 surfaces: xcb,xlib
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
Device-2: NVIDIA GA106 High Definition Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-4: Razer USA Nari Ultimate driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3
chip-ID: 1532:051a class-ID: 0300
Device-5: HTC (High Tech ) Vive driver: snd-usb-audio,uvcvideo type: USB
Device-6: HTC (High Tech ) Vive driver: hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9.1.5:16
chip-ID: 0bb4:2c87 class-ID: 0300 serial: <filter>
API: ALSA v: k6.10.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-1: Realtek Bluetooth 5.3 Radio driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 0bda:a729
rfk-block: hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10
Report-ID: ID: hci1 rfk-id: 1 state: up address: N/A
Local Storage: total: 7.28 TiB used: 5.9 TiB (81.1%)
fw-rev: 2B2QEXM7 temp: 55.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST6000VN0033-2EE110
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 1.72 TiB (96.6%)
used: 1.72 TiB (96.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.28 GiB used: 7.84 GiB (25.1%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6
ID-2: swap-2 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia temp: 45 C
Memory: total: 32 GiB available: 31.28 GiB used: 8.06 GiB (25.8%)
Processes: 330 Power: uptime: 22h 59m states: freeze,mem,disk
reboot, suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1916 libs: 572 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-01-26
Last full system update: 2024-09-01
Is partially upgraded: Yes
