Enabling HDR crashes desktop after wakeup
I recently got a new monitor with HDR capability. I can enable HDR in KDE’s display settings and it works fine, but if the display goes to sleep, I can’t get it to come back unless I reboot. When I do, the display configuration gets reset.
I’m not really sure what to try, as I’ve found nothing after several searches along the lines of “kde hdr desktop lockup” and variations of this, as well as just searching “hdr” on this forum. I have tried locking the desktop and letting the display go to sleep, then trying to wake it, with the display configured with:
  • high framerate and HDR (locks up)
  • high framerate and SDR (works fine)
  • normal framerate and HDR (locks up)
In every case that the desktop locks up, I’m still at least able to SSH in and run commands, so only KDE is locking up, not the computer.
Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=72ffa661-0906-45e7-b6ea-c1f101cbfd07 rw rootflags=subvol=@
quiet rd.luks.uuid=abeed2a4-928f-4b19-8772-780f1e6b54f8
rd.luks.uuid=207e7fc1-ccc1-49cf-a62a-e00d5b710422
resume=/dev/mapper/luks-207e7fc1-ccc1-49cf-a62a-e00d5b710422 loglevel=3
ibt=off nvidia-drm.modeset=1 intel_iommu=on iommu=pt
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_wayland with: krunner vt: 2 dm: SDDM Distro: Garuda
Mobo: ASUSTeK model: ROG STRIX B660-A GAMING WIFI D4 v: Rev 1.xx
UEFI: American Megatrends v: 2015 date: 10/19/2022
Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
microcode: 0x35
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/5100:5200:3900 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 801 12: 800 13: 800 14: 800
15: 800 16: 799 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 bogomips: 152985
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,DP-3,HDMI-A-1 empty: DP-1,HDMI-A-2
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11.4.2:14
chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 5760x1080
display-ID: 0
Monitor-1: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-3 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: center res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
memory: 11.72 GiB display-ID: :0.0
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.78 device-ID: 10de:2504
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
Device-4: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11.4.3:15
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-5: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:6
chip-ID: 0b05:1a16 class-ID: 0300
API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
IF-ID-1: br-6090d65a7b42 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-b4cee2a485be state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth6574abb state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth717513a state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0026
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 6.41 TiB used: 2.97 TiB (46.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 56.9 C
model: WD40EZAZ-19SF3B0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
model: WD10JMVW-11AJGS3 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1072 scheme: GPT
ID-1: / raw-size: 400 GiB size: 400 GiB (100.00%) used: 279.54 GiB (69.9%)
fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-abeed2a4-928f-4b19-8772-780f1e6b54f8
ID-2: /boot/efi raw-size: 768 MiB size: 766.5 MiB (99.80%)
used: 30.9 MiB (4.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 400 GiB size: 400 GiB (100.00%)
used: 279.54 GiB (69.9%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
ID-4: /var/log raw-size: 400 GiB size: 400 GiB (100.00%)
ID-5: /var/tmp raw-size: 400 GiB size: 400 GiB (100.00%)
ID-1: swap-1 type: partition size: 50 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-0 maj-min: 254:0
mapped: luks-207e7fc1-ccc1-49cf-a62a-e00d5b710422
ID-2: swap-2 type: zram size: 62.54 GiB used: 444.8 MiB (0.7%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 29.0 C mobo: N/A
Memory: total: 64 GiB available: 62.54 GiB used: 12.12 GiB (19.4%)
Processes: 642 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.95 GiB services: org_kde_powerdevil,
Packages: 2539 pm: pacman pkgs: 2531 libs: 616 tools: octopi,paru
pm: flatpak pkgs: 8 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date:     2023-11-14
Last full system update: 2024-05-21
Failed units:            home-jf-rffmpeg-cache.mount var-rffmpeg-chroot-cache.mount
HDR support is still pretty experimental in KDE 6.
I’ve checked around bugs.kde.org for a similar report to yours, but I am not sure I could quite find the exact reproduction steps you have listed. The closest ones I could find was 485403 – Enabling HDR freezes system
Take more of a look at bug reports there and see if there was anything I overlooked while looking for “HDR” in the keywords.
If nothing really matches up to your reproduction steps to your specific bug around HDR, make a new bug report. Be as detailed as you can, and include relevant logs. Be sure to also list the connection type, as I’ve seen issues listed to Nvidia HDMI 2.1 HDR 483697 – Cannot enable HDR when display is on Game Mode (Nvidia over HDMI 2.1)
Thank you for responding. I just checked the KDE Bugs list for any bugs of any status matching “HDR”; nothing matches exactly what I’m experiencing, but 485403 (which you linked) is the closest. 483999 also seems tangentially related, which was deemed an upstream bug with NVIDIA, in which case all I can really do is wait for 555 and see if that fixes it.
EDIT: No sooner do I post this that 555 becomes available on chaotic-aur/nvidia-beta-dkms. I installed it, rebooted, tried it again, and the display comes back from sleep now. It takes it a second to properly load in, but the actual problem seems to have been resolved.
