╭─[email protected] in ~ took 14ms
╰─λ garuda-inxi
Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b89a38fa-6eab-49d4-996e-9fcae4c49010 rw [email protected]
resume=UUID=93b25246-6f07-43e2-9317-28c4a4248cdf loglevel=3 ibt=off
Type: Desktop System: Dell product: OptiPlex 7010 v: 01
Mobo: Dell model: 0YXT71 v: A02 serial: <superuser required> UEFI: Dell
v: A21 date: 12/21/2015
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard
Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
desc: 1x6 MiB
Speed (MHz): avg: 1987 high: 3161 min/max: 1600/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1597 2: 1597 3: 3161
4: 1596 bogomips: 25542
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 ports: active: HDMI-A-1 empty: DVI-D-1
bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 36.0 C
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.3:3 chip-ID: 046d:0892
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Sceptre F27 serial: <filter>
built: 2021 res: 1920x1080 dpi: 81 gamma: 1.2 size: 600x330mm (23.62x12.99")
diag: 685mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 14.0.6 DRM 3.49 6.1.1-zen1-1-zen) direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel bus-ID: 1-1.3:3 v: kernel chip-ID: 046d:0892
bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0102 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam type: USB
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2725
driver: btusb v: 0.8 bus-ID: 3-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 931.51 GiB used: 21.63 GiB (2.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-1: / raw-size: 914.08 GiB size: 914.08 GiB (100.00%)
used: 21.63 GiB (2.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 914.08 GiB size: 914.08 GiB (100.00%)
ID-4: /var/log raw-size: 914.08 GiB size: 914.08 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.08 GiB size: 914.08 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 2.55 GiB (16.4%)
ID-2: swap-2 type: partition size: 17.14 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 3050
Processes: 325 Uptime: 7d 6h 36m wakeups: 135 Memory: 15.58 GiB
used: 9.36 GiB (60.1%) Init: systemd v: 252 default: graphical
pkgs: 2117 libs: 570 tools: octopi,pamac,paru Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-11-27
Last full system update: 2022-12-30 ↻
I try to open up Emacs(Client) from the KDE Menu which has the following setup
sh -c 'if [ -n "\$*" ]; then exec emacsclient --alternate-editor= --display="\$DISPLAY" "\[email protected]"; else exec emacsclient --alternate-editor= --create-frame; fi' placeholder %F
Nothing opens up, I have tried changing it to
emacsclient -c
but nothing opens. I am using the fish shell but have also tried it in bash.
if i type(in terminal):
sh -c -c 'if [ -n "\$*" ]; then exec emacsclient --alternate-editor= --display="\$DISPLAY" "\[email protected]"; else exec emacsclient --alternate-editor= --create-frame; fi' placeholder %F
then it opens correctly but not via the menu. Please help.
