hello
I am trying to play Star Trek Online and it says that the card is not compatable
this is what the game says it needs
Graphic Display
NVidia GeForce GTX 4xx, ATI/AMD Radeon HD 5xxx, or Intel HD Graphics 4xxx (Direct3D Hardware Feature Level 11)
Kernel: 5.19.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=2eb6e695-2930-46aa-b3b2-7f681515a795 rw rootflags=subvol=@
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Desktop System: Gigabyte product: Z68AP-D3 v: N/A serial: N/A
Chassis: type: 3 serial: N/A
Mobo: Gigabyte model: Z68AP-D3 serial: N/A BIOS: Award v: F8
date: 03/21/2012
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
Info: model: Intel Core i5-2500 socket: 478 (1155) note: check bits: 64
type: MCP arch: Sandy Bridge gen: core 2 level: v2 built: 2010-12
process: Intel 32nm family: 6 model-id: 0x2A (42) stepping: 7
microcode: 0x2F
desc: 1x6 MiB
Speed (MHz): avg: 2115 high: 2793 min/max: 1600/3300
base/boost: 3300/4000 scaling: driver: intel_cpufreq governor: performance
volts: 1.0 V ext-clock: 100 MHz cores: 1: 2793 2: 1596 3: 2475 4: 1596
bogomips: 26338
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
vendor: Gigabyte driver: i915 v: kernel arch: Gen-6 process: Intel 32nm
built: 2011 ports: active: none off: VGA-2 empty: DP-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0380
Device-2: NVIDIA GK107 [GeForce GT 640] vendor: ZOTAC driver: nouveau
v: kernel non-free: N/A status: unknown device ID pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1,VGA-1 empty: DVI-D-1 bus-ID: 06:00.0 chip-ID: 10de:0fc1
Device-3: Arkmicro Webcam Carrefour type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.5:4 chip-ID: 18ec:3299
class-ID: 0102
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa gpu: i915,nouveau display-ID: :0
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Samsung built: 2010
res: 1920x1080 hz: 60 dpi: 305 gamma: 1.4 size: 160x90mm (6.3x3.54")
diag: 801mm (31.5") ratio: 16:9 modes: max: 1360x768 min: 720x400
Monitor-2: VGA-1 pos: primary,left model: Dell E2211H serial: <filter>
built: 2010 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
Monitor-3: VGA-2 mapped: VGA-1-2 note: disabled size-res: N/A modes:
max: 1024x768 min: 640x480
OpenGL: renderer: NVE7 v: 4.3 Mesa 22.1.7 direct render: Yes
vendor: Gigabyte driver: snd_hda_intel bus-ID: 1-1.5:4 v: kernel
chip-ID: 18ec:3299 bus-ID: 00:1b.0 class-ID: 0102 chip-ID: 8086:1c20
Device-2: NVIDIA GK107 HDMI Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 10de:0e1b class-ID: 0403
Sound Server-1: ALSA v: k5.19.12-zen1-1-zen running: yes
lanes: 1 port: de00 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Edimax N150 Adapter type: USB driver: r8188eu bus-ID: 2-1.5:3
chip-ID: 7392:b811 class-ID: 0000 serial: <filter>
IF: wlp0s29u1u5 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-1.3:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.46 TiB used: 897.49 GiB (35.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3200822A
family: Barracuda 7200.7 and 7200.7 Plus size: 186.31 GiB block-size:
physical: 512 B logical: 512 B speed: 1.5 Gb/s type: N/A serial: <filter>
rev: 3.01 temp: 29 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 304d 0h cycles: 11782
Old-Age: UDMA CRC errors: 1072 alert: Bad cable/connection? Pre-Fail:
reallocated sector: 100 threshold: 36 attribute: Spin_Retry_Count
model: WD20EADS-00W4B0 family: Caviar Green size: 1.82 TiB block-size:
physical: 512 B logical: 512 B sata: 2.6 speed: 1.5 Gb/s type: N/A
serial: <filter> rev: 0A01 temp: 25 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 37d 10h cycles: 5426
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500418AS
family: Barracuda 7200.12 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 1.5 Gb/s type: HDD rpm: 7200
serial: <filter> rev: HP35 temp: 27 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 99d 14h cycles: 45282
Pre-Fail: reallocated sector: 100 threshold: 36 attribute: Spin_Retry_Count
ID-1: / raw-size: 186.31 GiB size: 186.31 GiB (100.00%) used: 130.71 GiB
(70.2%) fs: btrfs block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 186.31 GiB size: 186.31 GiB (100.00%) used: 130.71
GiB (70.2%) fs: btrfs block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 186.31 GiB size: 186.31 GiB (100.00%) used: 130.71
ID-4: /var/tmp raw-size: 186.31 GiB size: 186.31 GiB (100.00%) used: 130.71
System Temperatures: cpu: 24.0 C mobo: N/A gpu: nouveau temp: 24.0 C
Processes: 234 Uptime: 1h 19m wakeups: 18 Memory: 15.54 GiB used: 2.24 GiB
(14.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1950 libs: 553
tools: gnome-software,octopi,pamac,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-09-14
Last full system update: 2022-10-03 ↻
this is the inxi output
any help apprecieated
