I just installed Garuda Linux today (a few hours ago) and the audio didn’t work. I searched for solutions online and some people talked about changing to pulseaudio
and using pavucontrol
to manage audio. Instead of the default pipewire
So I installed pulseaudio
, maybe I did something wrong (though I didn’t modify any config file). Anyways, now my two monitors have the same image and I have a phantom “None-1-1” monitor on lxrandr
I’ve been searching for solutions on this issue for a few hours now, but I cannot find anything similar to it.
Inxi’s output:
Kernel: 6.5.6-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=2bb0de73-ab4f-4f97-836a-7cec1abe8309 rw rootflags=subvol=@
quiet rd.luks.uuid=c735f745-7334-4f22-b1f4-67e1faa36a39 quiet
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F50 date: 11/27/2019
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1725 high: 2800 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2800 2: 1550
3: 1550 4: 1336 5: 1550 6: 1550 7: 1550 8: 2800 9: 1550 10: 1375 11: 1550
12: 1550 bogomips: 81433
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Gigabyte
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 06:00.0
chip-ID: 10de:21c4 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-b700a
driver: X: loaded: modesetting,nouveau,nvidia alternate: fbdev,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62")
Monitor-1: DP-4 pos: primary res: 1920x1080 hz: 60 dpi: 92
size: 530x300mm (20.87x11.81") diag: 609mm (23.98") modes: N/A
Monitor-2: HDMI-0 pos: primary res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: Vulkan v: 1.3.264 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 SUPER driver: nvidia v: 535.113.01 device-ID: 10de:21c4
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
bus-ID: 06:00.1 chip-ID: 10de:1aeb class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.3
API: ALSA v: k6.5.6-zen2-1-zen status: kernel-api tools: N/A
Server-1: PulseAudio v: 16.1 status: active with: pulseaudio-jack
type: module tools: pacat,pactl,pavucontrol
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
Local Storage: total: 1.35 TiB used: 9.16 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
model: WDS480G2G0B-00EPW0 size: 447.14 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000
ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
used: 9.16 GiB (1.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-c735f745-7334-4f22-b1f4-67e1faa36a39
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-4: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.8 C mobo: 40.0 C gpu: nvidia temp: 50 C
Processes: 310 Uptime: 30m wakeups: 0 Memory: total: 16 GiB
available: 15.56 GiB used: 2.42 GiB (15.6%) Init: systemd v: 254
pm: pacman pkgs: 1296 libs: 376 tools: octopi,paru Shell: Zsh v: 5.9
running-in: alacritty inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-10
Last full system update: 2023-10-10
Thanks for helping!
