Recently I have extra entries in my Grub menu that I can't seem to get rid of. Any Ideas on how to get this back to Garuda stock without all the duplicate entries?
When I do a grub-update or reinstall of grub I get the following
Fix 'GRUB' and 'os-prober' after upgrading either of them
===> INFO: grub-tools / grub-fix-initrd-generation:
===> INFO: /etc/grub.d/30_os-prober changed. See file /var/log/grub-fix-initrd-generation.log.
===> INFO: /etc/grub.d/10_linux changed. See file /var/log/grub-fix-initrd-generation.log.
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: initramfs-linux-zen-fallback.img
Found Windows Boot Manager on /dev/[email protected]/EFI/Microsoft/Boot/bootmgfw.efi
Found Garuda Linux on /dev/nvme0n1p5
Detecting snapshots ...
Info: Separate boot partition not detected
Found snapshot: 2021-04-02 15:38:06 | timeshift-btrfs/snapshots/2021-04-02_15-38-06/@
Found snapshot: 2021-04-02 13:50:33 | timeshift-btrfs/snapshots/2021-04-02_13-50-33/@
Found snapshot: 2021-04-01 16:23:04 | timeshift-btrfs/snapshots/2021-04-01_16-23-04/@
Found snapshot: 2021-03-30 16:16:35 | timeshift-btrfs/snapshots/2021-03-30_16-16-35/@
Found snapshot: 2021-03-30 15:01:30 | timeshift-btrfs/snapshots/2021-03-30_15-01-30/@
Found 5 snapshot(s)
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
I've tried removing the .bak files from /etc/grub.d/
but after updating grub the duplicates are still there. Below is a screenshot of the config files in that directory.
