Kernel: 5.13.0-7614-generic x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13.0-7614-generic
root=UUID=ba8e9f9d-79ff-4357-bdc8-a8a807970369 ro quiet splash
vt.handoff=7
Desktop: GNOME 3.38.4 tk: GTK 3.24.25 wm: gnome-shell dm: GDM3 3.38.2.1
Distro: Pop!_OS 21.04 base: Ubuntu 21.04 Hirsute
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
serial: <filter> UEFI [Legacy]: American Megatrends v: 5602
date: 07/14/2020
Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics
bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23)
model-id: 18 (24) stepping: 1 microcode: 8108109 L2 cache: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 59087
Speed: 1258 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz):
1: 1258 2: 1258 3: 1258 4: 1259 5: 1259 6: 1258 7: 1264 8: 1260
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
disabled, RSB filling
Device-1: AMD Navi 23 vendor: Sapphire Limited driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:73ff class ID: 0300
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 0a:00.0 chip ID: 1002:15d8 class ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: fbdev,modesetting,radeon,vesa display ID: :1
Screen-1: 0 s-res: 2688x1468 s-dpi: 96 s-size: 711x388mm (28.0x15.3")
s-diag: 810mm (31.9")
Monitor-1: DisplayPort-3 res: 768x1366 hz: 60
Monitor-2: HDMI-A-1-0 res: 1920x1080 dpi: 90 size: 542x305mm (21.3x12.0")
diag: 622mm (24.5")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.41.0
5.13.0-7614-generic LLVM 12.0.0)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:ab28 class ID: 0403
Device-2: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel
bus ID: 0a:00.1 chip ID: 1002:15de class ID: 0403
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK PRIME B450M-A
driver: snd_hda_intel v: kernel bus ID: 0a:00.6 chip ID: 1022:15e3
class ID: 0403
Sound Server: ALSA v: k5.13.0-7614-generic
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: e000
bus ID: 08:00.0 chip ID: 10ec:8168 class ID: 0200
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.38 TiB used: 169.08 GiB (6.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0107 scheme: GPT
model: WDS120G2G0B-00EPW0 size: 111.8 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0000
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD My Passport 0827 size: 1.82 TiB block size: physical: 512 B
logical: 512 B serial: <filter> rev: 1012 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 14.61 GiB block size: physical: 512 B logical: 512 B
ID-1: / raw size: 107.79 GiB size: 105.6 GiB (97.97%)
used: 6.38 GiB (6.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-0 maj-min: 253:0 mapped: cryptswap
Message: No sensors data was found. Is sensors configured?
Processes: 311 Uptime: 11m wakeups: 0 Memory: 13.59 GiB
used: 1.82 GiB (13.4%) Init: systemd v: 247 runlevel: 5 Compilers:
gcc: 10.3.0 alt: 10 Packages: apt: 1744 lib: 875 flatpak: 0 Shell: Bash
v: 5.1.4 running in: gnome-terminal inxi: 3.3.01
Hello again, a few hours ago I was struggling with an issue regarding geruda and my dual monitor setup. I gave up and tried a few other distros resulting in me going back to Pop OS and having the exact same issue. I am running two monitors, one of them is unusable (My main one) when using certain applications like firefox or typing in any application.
If I can fix this I will just revert back to geruda, so if anyone has any idea about how to fix this, I'd appreciate the help. Couldn't find anything online. Thanks.
