Hello!
I use my laptop with a second monitor, and I've notice that when I maximize a window, you can see the edge of the window in the other monitor. It's just a 1-2 px stripe, but it messes around with some programs like latte.
Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=687c1e5f-6fd1-49db-8c68-ddf00ee5bac9 rw [email protected]
resume=UUID=eef151b2-ca3b-4eda-9dd7-3b73fb9f3938 loglevel=3 ibt=off
Type: Laptop System: Micro-Star product: GS66 Stealth 10SE v: REV:1.0
Mobo: Micro-Star model: MS-16V1 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16V1IMS.112 date: 11/19/2020
ID-1: BAT1 charge: 50.2 Wh (60.1%) condition: 83.5/95.0 Wh (87.9%)
volts: 15.6 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-10875H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4098 high: 4600 min/max: 800/5100 scaling:
driver: intel_pstate governor: performance cores: 1: 4578 2: 4588 3: 4595
4: 4572 5: 4592 6: 4572 7: 2300 8: 2300 9: 2300 10: 4473 11: 4600 12: 4561
13: 4491 14: 4570 15: 3968 16: 4522 bogomips: 73598
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Acer HD Camera type: USB driver: uvcvideo bus-ID: 1-11:5
chip-ID: 5986:2127 class-ID: 0e02 serial: <filter>
Device-4: MacroSilicon USB Video type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 1-4:3
chip-ID: 534d:2109 class-ID: 0300
Screen-1: 0 s-res: 3839x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: left res: 1920x1080 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
Monitor-2: eDP-1 pos: primary,right res: 1920x1080 hz: 240 dpi: 142
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel UHD Graphics (CML GT2)
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-4:3 chip-ID: 534d:2109
class-ID: 0300 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
Device-3: MacroSilicon USB Video type: USB
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
Device-2: Intel driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: N/A bus-ID: 3d:00.0 chip-ID: 8086:3101 class-ID: 0200
IF: enp61s0 state: down mac: <filter>
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.84 TiB used: 244.67 GiB (13.0%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1032 size: 953.87 GiB block-size: physical: 512 B
rev: 11111000 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
used: 244.67 GiB (27.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
used: 612 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
ID-4: /var/log raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.28 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8
ID-2: swap-2 type: zram size: 31.16 GiB used: 2.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 82.0 C pch: 56.0 C mobo: N/A
Processes: 339 Uptime: 7m wakeups: 819 Memory: 31.16 GiB
used: 5.17 GiB (16.6%) Init: systemd v: 252 default: graphical
pkgs: 2094 libs: 564 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-12-17
Last full system update: 2022-12-24
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
