Dual Monitor fails to work
I have a laptop with a RTX 3050. I tried installing with Nvidia Drivers and after the system update. Dual Monitor is not working.
Should I choose Install with Open Drivers or Install with Nvidia Drivers during installation from iso file
How should I install Nvidia Drivers from this below link
Note : Dual Monitor is not working in the latest iso of Garuda Linux Dra460nized
If you are able to get your installation up with the proprietary drivers option, that is most likely the best place to start.
From there, please post the output of garuda-inxi and provide as much information as possible about the monitor setup you are trying to configure (the more details the better).
This is what I got by running garuda-inxi
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
v: kernel arch: RDNA 2 process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5 bus-ID: 05:00.0 chip-ID: 1002:1681
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: amdgpu
Monitor-1: HDMI-1-0 size-res: N/A modes: N/A
Monitor-2: eDP pos: primary res: 1920x1080 hz: 144 dpi: 142
OpenGL:
renderer: AMD YELLOW_CARP (LLVM 13.0.1 DRM 3.46 5.18.8-zen1-1-zen)
v: 4.6 Mesa 22.1.2 direct render: Yes
Monitor is LG ultrawide 29 inch resolution is 2560 x 1080 75hz
I just edit your post :slight_smile:
We need the complete in- and output :slight_smile:
bla
bla
in formatted text, like above.
Kernel: 5.18.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=be7ec201-c74d-4ea6-93d1-9f5e2d177c40 rw [email protected]
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: ASUSTeK product: ROG Strix G513RC_G513RC v: 1.0
Mobo: ASUSTeK model: G513RC v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513RC.317 date: 05/30/2022
ID-1: BAT0 charge: 33.8 Wh (60.0%) condition: 56.3/56.0 Wh (100.6%)
volts: 15.4 min: 15.9 model: AS3GWZC3KC G513-36 type: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K230
Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 built: 2022 process: TSMC n6 (7nm) family: 0x19 (25)
model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1418 high: 1882 min/max: 1600/4784 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1341 2: 1367
3: 1388 4: 1377 5: 1385 6: 1376 7: 1371 8: 1381 9: 1410 10: 1498 11: 1383
12: 1391 13: 1366 14: 1393 15: 1882 16: 1390 bogomips: 102206
STIBP: always-on, RSB filling
OpenGL:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_pci_acp6x v: kernel
alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_acp_pci,snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Sound Server-1: ALSA v: k5.18.8-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.53 running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 476.94 GiB used: 11.26 GiB (2.4%)
model: 2450 MTFDKBA512TFK size: 476.94 GiB block-size: physical: 512 B
rev: V5MA010 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 64 GiB size: 64 GiB (100.00%) used: 11.23 GiB (17.5%)
fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
used: 28 MiB (10.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 64 GiB size: 64 GiB (100.00%)
used: 11.23 GiB (17.5%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
ID-4: /var/log raw-size: 64 GiB size: 64 GiB (100.00%)
ID-5: /var/tmp raw-size: 64 GiB size: 64 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.89 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 53.0 C
Processes: 335 Uptime: 0m wakeups: 6 Memory: 14.89 GiB
used: 1.46 GiB (9.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1208 lib: 306
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date:     2022-07-03
Last full system update: 2022-07-02
:thinking:
Strange
Just few hours before I have reinstalled and tried
Post Xorg log, at a web pastebin service (like bin.garudalinux.org)
cat /var/log/Xorg.0.log
