cannot run my editing apps with DRI_PRIME command as they crash...
this command was successfull with only ubuntu...
any suggestions...
any suggestions...
Output of
inxi -Fxxxza
Two things:
it looks normal... no.errors nor red marks... just the app.freezes and then crashes
do anyone have any suggestion​:sob:
Start in the terminal, post the output as recommended above.
Please only post terminal output as text (not pictures).
this is what i got before freezing and then I had to force stop it...
DRI_PRIME=1 kdenlive 
qt.svg: link #path2410 is undefined!
Icon theme "Numix-Circle-Light" not found.
Using modified system locale without group separator for numbers
mlt_repository_init: failed to dlopen /usr/lib/mlt/libmltopencv.so
(libopencv_tracking.so.4.4: cannot open shared object file: No such file or directory)
mlt_repository_init: failed to dlopen /usr/lib/mlt/libmltrtaudio.so
(librtaudio.so.6: cannot open shared object file: No such file or directory)
mlt_repository_init: failed to dlopen /usr/lib/mlt/libmltsdl.so
(libSDL_image-1.2.so.0: cannot open shared object file: No such file or directory)
mlt_repository_init: failed to dlopen /usr/lib/mlt/libmltsox.so
(libsox.so.3: cannot open shared object file: No such file or directory)
LC_NUMERIC reset to C
NEW LC_ALL LC_CTYPE=en_IN.UTF-8;LC_NUMERIC=C;LC_TIME=en_IN.UTF-8;LC_COLLATE=en_IN.UTF-8;LC_MONETARY=en_IN.UTF-8;LC_MESSAGES=en_IN.UTF-8;LC_PAPER=en_IN;LC_NAME=en_IN;LC_ADDRESS=en_IN;LC_TELEPHONE=en_IN;LC_MEASUREMENT=en_IN.UTF-8;LC_IDENTIFICATION=en_IN
Metadata for "avcolour_space" is invalid.
WARNING : Fails to parse "avcolour_space"
Metadata for "avcolor_space" is invalid.
WARNING : Fails to parse "avcolor_space"
Metadata for "avdeinterlace" is invalid.
WARNING : Fails to parse "avdeinterlace"
Metadata for "swscale" is invalid.
WARNING : Fails to parse "swscale"
"avfilter.abench" is blacklisted
"avfilter.acompressor" is blacklisted
"avfilter.adelay" is blacklisted
"avfilter.aecho" is blacklisted
"avfilter.aemphasis" is blacklisted
"avfilter.aeval" is blacklisted
"avfilter.afade" is blacklisted
"avfilter.afftfilt" is blacklisted
"avfilter.agate" is blacklisted
"avfilter.ametadata" is blacklisted
"avfilter.arealtime" is blacklisted
"avfilter.ashowinfo" is blacklisted
"avfilter.channelmap" is blacklisted
"avfilter.chorus" is blacklisted
"avfilter.earwax" is blacklisted
"avfilter.volume" is blacklisted
"avfilter.volumedetect" is blacklisted
"avfilter.ass" is blacklisted
"avfilter.atadenoise" is blacklisted
"avfilter.avgblur" is blacklisted
"avfilter.bbox" is blacklisted
"avfilter.bench" is blacklisted
"avfilter.blackdetect" is blacklisted
"avfilter.blackframe" is blacklisted
"avfilter.boxblur" is blacklisted
"avfilter.bwdif" is blacklisted
"avfilter.chromakey" is blacklisted
"avfilter.colorkey" is blacklisted
"avfilter.colormatrix" is blacklisted
"avfilter.colorspace" is blacklisted
"avfilter.convolution" is blacklisted
"avfilter.crop" is blacklisted
"avfilter.cropdetect" is blacklisted
"avfilter.curves" is blacklisted
"avfilter.datascope" is blacklisted
"avfilter.dctdnoiz" is blacklisted
"avfilter.deband" is blacklisted
"avfilter.deflate" is blacklisted
"avfilter.deinterlace_vaapi" is blacklisted
"avfilter.deshake" is blacklisted
"avfilter.despill" is blacklisted
"avfilter.doubleweave" is blacklisted
"avfilter.drawbox" is blacklisted
"avfilter.drawgraph" is blacklisted
"avfilter.drawgrid" is blacklisted
"avfilter.drawtext" is blacklisted
"avfilter.elbg" is blacklisted
"avfilter.eq" is blacklisted
"avfilter.fade" is blacklisted
"avfilter.field" is blacklisted
"avfilter.fieldhint" is blacklisted
"avfilter.fieldorder" is blacklisted
"avfilter.find_rect" is blacklisted
"avfilter.floodfill" is blacklisted
"avfilter.fspp" is blacklisted
"avfilter.gblur" is blacklisted
"avfilter.geq" is blacklisted
"avfilter.hflip" is blacklisted
"avfilter.hqdn3d" is blacklisted
"avfilter.hqx" is blacklisted
"avfilter.hue" is blacklisted
"avfilter.hwdownload" is blacklisted
"avfilter.idet" is blacklisted
"avfilter.il" is blacklisted
"avfilter.lenscorrection" is blacklisted
"avfilter.loop" is blacklisted
"avfilter.lumakey" is blacklisted
"avfilter.lut" is blacklisted
"avfilter.lutrgb" is blacklisted
"avfilter.lutyuv" is blacklisted
"avfilter.mcdeint" is blacklisted
"avfilter.metadata" is blacklisted
"avfilter.negate" is blacklisted
"avfilter.nlmeans" is blacklisted
"avfilter.nnedi" is blacklisted
"avfilter.owdenoise" is blacklisted
"avfilter.pad" is blacklisted
"avfilter.perspective" is blacklisted
"avfilter.phase" is blacklisted
"avfilter.pixscope" is blacklisted
"avfilter.pp" is blacklisted
"avfilter.pp7" is blacklisted
"avfilter.prewitt" is blacklisted
"avfilter.realtime" is blacklisted
"avfilter.removegrain" is blacklisted
"avfilter.removelogo" is blacklisted
"avfilter.roberts" is blacklisted
"avfilter.rotate" is blacklisted
"avfilter.scale_vaapi" is blacklisted
"avfilter.showinfo" is blacklisted
"avfilter.shuffleframes" is blacklisted
"avfilter.sidedata" is blacklisted
"avfilter.signalstats" is blacklisted
"avfilter.sobel" is blacklisted
"avfilter.stereo3d" is blacklisted
"avfilter.super2xsai" is blacklisted
"avfilter.swapuv" is blacklisted
"avfilter.tblend" is blacklisted
"avfilter.tlut2" is blacklisted
"avfilter.tonemap" is blacklisted
"avfilter.transpose" is blacklisted
"avfilter.vectorscope" is blacklisted
"avfilter.vflip" is blacklisted
"avfilter.vignette" is blacklisted
"avfilter.vmafmotion" is blacklisted
"avfilter.w3fdif" is blacklisted
"avfilter.xbr" is blacklisted
"avfilter.yadif" is blacklisted
"avfilter.zoompan" is blacklisted
Metadata for "swresample" is invalid.
WARNING : Fails to parse "swresample"
Metadata for "audiochannels" is invalid.
WARNING : Fails to parse "audiochannels"
Metadata for "audioconvert" is invalid.
WARNING : Fails to parse "audioconvert"
Metadata for "data_feed" is invalid.
WARNING : Fails to parse "data_feed"
"data_show" is blacklisted
Metadata for "imageconvert" is invalid.
WARNING : Fails to parse "imageconvert"
"mask_apply" is blacklisted
"mask_start" is blacklisted
"mono" is blacklisted
"region" is blacklisted
"resize" is blacklisted
"transition" is blacklisted
"watermark" is blacklisted
"frei0r.3dflippo" is blacklisted
"frei0r.bluescreen0r" is blacklisted
"frei0r.bw0r" is blacklisted
"frei0r.gamma" is blacklisted
"frei0r.invert0r" is blacklisted
"frei0r.rgbsplit0r" is blacklisted
"frei0r.tehRoxx0r" is blacklisted
"frei0r.transparency" is blacklisted
"frei0r.vertigo" is blacklisted
"gtkrescale" is blacklisted
Metadata for "jack" is invalid.
WARNING : Fails to parse "jack"
"jackrack" is blacklisted
"motion_est" is blacklisted
Invalid title/identifier for "crop_detect"
WARNING : Fails to parse "crop_detect"
Metadata for "glsl.manager" is invalid.
WARNING : Fails to parse "glsl.manager"
Metadata for "movit.convert" is invalid.
WARNING : Fails to parse "movit.convert"
Metadata for "movit.crop" is invalid.
WARNING : Fails to parse "movit.crop"
Metadata for "movit.resample" is invalid.
WARNING : Fails to parse "movit.resample"
Metadata for "movit.resize" is invalid.
WARNING : Fails to parse "movit.resize"
"rgblut" is blacklisted
"spot_remover" is blacklisted
"text" is blacklisted
"timer" is blacklisted
"burningtv" is blacklisted
Metadata for "telecide" is invalid.
WARNING : Fails to parse "telecide"
"qtext" is blacklisted
"resample" is blacklisted
"videostab" is blacklisted
"videostab2" is blacklisted
Metadata for "deinterlace" is invalid.
WARNING : Fails to parse "deinterlace"
++++++ Unknown asset : "avfilter.acompressor"
++++++ Unknown asset : "avfilter.aecho"
++++++ Unknown asset : "avfilter.agate"
Warning: duplicate custom definition of effect "frei0r.alpha0ps" found. Only last one will be considered. Duplicate found in "/usr/share/kdenlive/effects/frei0r_alpha0ps.xml"
Warning: duplicate custom definition of effect "frei0r.balanc0r" found. Only last one will be considered. Duplicate found in "/usr/share/kdenlive/effects/frei0r_balanc0r.xml"
Warning: duplicate custom definition of effect "frei0r.curves" found. Only last one will be considered. Duplicate found in "/usr/share/kdenlive/effects/frei0r_curves.xml"
++++++ Unknown asset : "frei0r.facebl0r"
++++++ Unknown asset : "frei0r.facedetect"
Warning: duplicate custom definition of effect "frei0r.levels" found. Only last one will be considered. Duplicate found in "/usr/share/kdenlive/effects/frei0r_levels.xml"
Warning: duplicate custom definition of effect "frei0r.lightgraffiti" found. Only last one will be considered. Duplicate found in "/usr/share/kdenlive/effects/frei0r_lightgraffiti.xml"
Warning: duplicate custom definition of effect "frei0r.select0r" found. Only last one will be considered. Duplicate found in "/usr/share/kdenlive/effects/frei0r_select0r.xml"
Warning: duplicate custom definition of effect "frei0r.sopsat" found. Only last one will be considered. Duplicate found in "/usr/share/kdenlive/effects/frei0r_sopsat.xml"
++++++ Unknown asset : "frei0r.tehRoxx0r"
++++++ Unknown asset : "frei0r.vertigo"
++++++ Unknown asset : "movit.unsharp_mask"
Warning: duplicate custom definition of effect "qtblend" found. Only last one will be considered. Duplicate found in "/usr/share/kdenlive/effects/qtblend.xml"
++++++ Unknown asset : "region"
++++++ Unknown asset : "sox"
++++++ Unknown asset : "timewarp"
++++++ Unknown asset : "opencv.tracker"
"frei0r.alphainjection" is blacklisted
"frei0r.blend" is blacklisted
"frei0r.composition" is blacklisted
"frei0r.xfade0r" is blacklisted
Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
QQmlEngine::setContextForObject(): Object already has a QQmlContext
file:///usr/lib/qt/qml/QtQuick/Controls/TableViewColumn.qml:66:1: QML TableViewColumn: Accessible must be attached to an Item
qrc:/qml/assetList.qml:314:13: QML Menu: Accessible must be attached to an Item
QWidget::setMinimumSize: (effect_list/QDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (transition_list/QDockWidget) Negative sizes (0,-1) are not possible
qrc:/qml/timeline.qml:1459:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Loading bin playlist...
Trying to construct 5 tracks.
SUSPICIOUS: we weren't expecting a producer when parsing the timeline
=== REQUESTING TRACK INSERTION AT: -1
qml: GOT SCALE: 0.62 , BASE: 10 - SNAPPING: 16
^C
Does anybody have an answer for this yet?
Open new topic, please.
Post inxi as text.
