all apps are white theme
this post is on the right track
but its closed.
but its closed.
this one too
Just because a top scorer didn’t score a goal in the last game doesn’t mean that soccer itself is dead.
Please don’t post here in the forum, like in chat forums.
As long as no one has replied to your post, you can edit your post.
By the way, there will always be people who have a problem that only affects them. This may be due to their hardware or the software they have loaded onto their computer.
Posts are closed by the forum software after a certain time. If there are new findings, they will be reopened by the moderators.
You might just need to update
Please always post the garuda-inxi
when making Issues & Assistance topics.
Why did you change the click bait headline?
In my opinion, it’s not a problem of dragonized theme just because some apps don’t adopt it.
That’s not right.
Because this isn’t Youtube?
You might want to recheck your global theme settings if it is more than just white GTK apps like in the topics linked. Did it somehow change to default Breeze (white) or something?
Sorry for the post format.
> System:
Host: staminstrix Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 14.2.1 clocksource: tsc avail: acpi_pm
root=UUID=96027b0c-1e9d-4b46-8fec-d7788ff1d4d4 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Laptop System: ASUSTeK product: ROG Strix G713RW_G713RW v: 1.0
Mobo: ASUSTeK model: G713RW v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G713RW.323
date: 10/16/2022
ID-1: BAT0 charge: 78.6 Wh (100.0%) condition: 78.6/90.0 Wh (87.3%)
volts: 16.8 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown serial: 2F03
status: full
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Speed (MHz): avg: 3268 min/max: 400/4935 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3268 2: 3268 3: 3268
4: 3268 5: 3268 6: 3268 7: 3268 8: 3268 9: 3268 10: 3268 11: 3268 12: 3268
13: 3268 14: 3268 15: 3268 16: 3268 bogomips: 105411
Type: gather_data_sampling status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW;
STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 ports: active: none off: DP-6,eDP-2
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:24a0 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: none empty: DP-1, DP-2, DP-3, DP-4, DP-5,
Writeback-1, eDP-1 bus-ID: 05:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 59.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.3
compositor: kwin_x11 driver: X: loaded: modesetting failed: nvidia
dri: radeonsi gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
s-diag: 777mm (30.58")
Monitor-1: DP-0 pos: primary res: 2560x1440 dpi: 108
size: 600x350mm (23.62x13.78") diag: 695mm (27.35") modes: N/A
Monitor-2: DP-2 size-res: N/A modes: N/A
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.295 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti Laptop GPU driver: nvidia v: 560.35.03
device-ID: 10de:24a0 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 24.2.5-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.5-arch1.1 (LLVM
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
vendor: ASUSTeK driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
vendor: AzureWave ASUS PCE-AXE59BT driver: mt7921e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7922 class-ID: 0280
IF: wlo1 state: down mac: c6:86:b1:66:79:42
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: e2:8f:75:63:11:94
IF-ID-1: surfshark_ipv6 state: unknown speed: N/A duplex: N/A
mac: 12:06:9b:3a:5f:9c
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 13d3:3568
class-ID: e001 serial: 000000000
rfk-block: hardware: no software: yes address: B4:8C:9D:5B:0B:FC bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no
Local Storage: total: 953.87 GiB used: 874.26 GiB (91.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA1T0TFK
lanes: 4 tech: SSD serial: 214632F4AAC7 fw-rev: V5MA010 temp: 29.9 C
used: 874.26 GiB (91.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.61 GiB used: 5.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 68.4 C mobo: 45.5 C
GPU: device: nvidia screen: :0.0 temp: 58 C device: amdgpu temp: 60.0 C
Memory: total: 32 GiB note: est. available: 30.61 GiB used: 4.04 GiB (13.2%)
Processes: 420 Power: uptime: 20m states: freeze,mem,disk suspend: s2idle
image: 12.17 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1951 libs: 562 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: fish v: 3.7.1 default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.36
It happens on Surfshark ,Nvidia Settings GUI and Lutris GUI , the 2 apps I use the most, they are both white and make eyes bleed now.
This issue appeared after I updated.
I’m sorry, but when was your last update? Your garuda-inxi
is missing that information at the end there. Be sure to run garuda-update
to grab the very recent bump for plasma5-themes-sweet-full-git
, which should be version r390.48a9050-1.1
dated 2024-10-26 . A reboot might also be needed.
Edit: Fixed on my end by selecting Sweet-Dark theme for “GNOME/GTK Application Style” which got unset… again (I really should have checked that one first )
I have the same issue since updating 24 hours ago.
First noticed it with GnuCash. Also in Nvidia Server Settings and Lutris as tag wrote. Firefox seems unaffected.
Updated and rebooted just now, but the issue is still there
╰─λ garuda-inxi
Kernel: 6.6.58-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=dcd7f8a1-1111-4981-9690-7075f3180680 rw rootflags=subvol=@
resume=UUID=806bc1a6-5808-4180-bd6e-260e718dee72 loglevel=3
nvidia-drm.modeset=1 ibt=off
wm: kwin_x11 tools: avail: lxlock vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: LENOVO product: 82JQ v: LEGION5PRO-16ACH6H
serial: <superuser required> Chassis: type: 10 v: LEGION5PRO-16ACH6H
Mobo: LENOVO model: LNVNB161216 v: SDK0K17763 WIN
part-nu: LENOVO_MT_82JQ_BU_idea_FM_LEGION5PRO-16ACH6H
uuid: <superuser required> UEFI: LENOVO v: GKCN65WW date: 01/16/2024
ID-1: BAT0 charge: 75.5 Wh (98.1%) condition: 77.0/80.0 Wh (96.2%)
volts: 16.0 min: 15.4 model: Sunwoda L20D4PC1 type: Li-poly serial: <filter>
status: not charging cycles: 34
microcode: 0xA50000F
Speed (MHz): avg: 2395 min/max: 400/4463 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 2395 2: 2395 3: 2395 4: 2395 5: 2395 6: 2395
7: 2395 8: 2395 9: 2395 10: 2395 11: 2395 12: 2395 13: 2395 14: 2395
15: 2395 16: 2395 bogomips: 102254
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Lenovo
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:24dd
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 6400x2160 s-dpi: 139 s-size: 1169x392mm (46.02x15.43")
s-diag: 1233mm (48.54")
Monitor-1: DP-2 note: disabled pos: right model: Gigabyte M32U
serial: <filter> built: 2022 res: 3840x2160 hz: 60 dpi: 140 gamma: 1.2
max: 3840x2160 min: 640x480
Monitor-2: eDP-1 mapped: DP-4 note: disabled pos: primary,left
model: BOE Display 0x0a40 built: 2021 res: 2560x1600 hz: 60 dpi: 189
gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
modes: 2560x1600
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Laptop
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Laptop GPU driver: nvidia v: 560.35.03
device-ID: 10de:24dd surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
Device-4: Creative Pebble V3 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.4.2:6
chip-ID: 041e:3272 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.58-1-lts status: kernel-api with: aoss
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 1000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:5 chip-ID: 0bda:4852
Local Storage: total: 9.27 TiB used: 5.33 TiB (57.5%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Lexar model: SSD NM790 4TB
size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 12237 temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Transcend model: TS4TSSD230S
size: 3.73 TiB block-size: physical: 4096 B logical: 4096 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: W14B scheme: GPT
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 1.55 TiB (85.9%)
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
used: 1.55 TiB (85.9%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.47 GiB used: 139.8 MiB (0.9%)
ID-2: swap-2 type: partition size: 14.86 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3
System Temperatures: cpu: 61.9 C mobo: N/A gpu: nvidia temp: 51 C
Memory: total: 16 GiB available: 15.48 GiB used: 4.17 GiB (27.0%)
Processes: 407 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1991 libs: 552 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
System install date: 2023-05-10
Last full system update: 2024-10-30
date: 10/16/2022
status: full
affected
temp: 59.0 C
inxi: 3.3.36
that is how it finishes.
I update frequently.
Post from terminal the command and the output.
We are missing some lines.
Look at
â•─stamina@staminstrix in ~
╰─λ inxi -Fxxxa
date: 10/16/2022
status: full
Speed (MHz): avg: 1099 min/max: 400/4935 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1099 2: 1099 3: 1099
4: 1099 5: 1099 6: 1099 7: 1099 8: 1099 9: 1099 10: 1099 11: 1099 12: 1099
13: 1099 14: 1099 15: 1099 16: 1099 bogomips: 105399
affected
temp: 58.0 C
IF: wlo1 state: down mac: 32:68:57:25:77:22
Local Storage: total: 953.87 GiB used: 882.22 GiB (92.5%)
lanes: 4 tech: SSD serial: 214632F4AAC7 fw-rev: V5MA010 temp: 30.9 C
used: 882.22 GiB (92.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.61 GiB used: 6.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 66.6 C mobo: 43.8 C
Fan Speeds (rpm): cpu: 3100
GPU: device: nvidia screen: :0.0 temp: 57 C device: amdgpu temp: 58.0 C
Memory: total: 32 GiB note: est. available: 30.61 GiB used: 5.72 GiB (18.7%)
Processes: 419 Power: uptime: 15m states: freeze,mem,disk suspend: s2idle
inxi: 3.3.36
wrong command
â•─stamina@staminstrix in ~ took 2s
╰─λ garuda-inxi
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
date: 10/16/2022
serial: <filter> status: full
Speed (MHz): avg: 4601 min/max: 400/4935 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4601 2: 4601 3: 4601
4: 4601 5: 4601 6: 4601 7: 4601 8: 4601 9: 4601 10: 4601 11: 4601 12: 4601
13: 4601 14: 4601 15: 4601 16: 4601 bogomips: 105399
temp: 59.0 C
IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
mac: <filter>
lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 28.9 C
System Temperatures: cpu: 66.4 C mobo: 43.8 C
Fan Speeds (rpm): cpu: 3300
Memory: total: 32 GiB note: est. available: 30.61 GiB used: 5.74 GiB (18.8%)
Processes: 422 Power: uptime: 17m states: freeze,mem,disk suspend: s2idle
gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.36
System install date: 2022-12-31
Last full system update: 2024-10-29
I don’t know this , I have to search it, never used it.
â•─stamina@staminstrix in ~ took 3s
╰─λ nwg-look
INFO[0000] /home/stamina/.config/nwg-look/config file not found, creating
INFO[0000] lang: en_GB
INFO[0000] >>> Loading basic lang from '/usr/share/nwg-look/langs/en_US.json'
Gtk-Message: 12:59:53.782: Failed to load module "appmenu-gtk-module"
INFO[0000] >>> Parsing original /home/stamina/.config/gtk-3.0/settings.ini
WARN[0000] Unsupported config key: gtk-decoration-layout
WARN[0000] Unsupported config key: gtk-enable-animations
WARN[0000] Unsupported config key: gtk-modules
WARN[0000] Unsupported config key: gtk-primary-button-warps-slider
WARN[0000] Unsupported config key: gtk-shell-shows-menubar
WARN[0000] Unsupported config key: gtk-sound-theme-name
WARN[0000] Unsupported config key: gtk-xft-dpi
INFO[0000] >>> Reading gsettings
INFO[0000] gtk-theme: sweet
INFO[0000] icon-theme: BeautyLine
INFO[0000] font-name: Fira Sans, 10
INFO[0000] cursor-theme: Sweet-cursors
INFO[0000] cursor-size: 24
INFO[0000] toolbar-style: text
INFO[0000] toolbar-icons-size: large
INFO[0000] font-hinting: slight
INFO[0000] font-antialiasing: grayscale
INFO[0000] font-rgba-order: rgb
INFO[0000] text-scaling-factor: 1
INFO[0000] color-scheme: prefer-dark
INFO[0000] event-sounds: true
INFO[0000] input-feedback-sounds: false
INFO[0015] >>> Applying gsettings
INFO[0015] >> org.gnome.desktop.interface
INFO[0015] gtk-theme: Sweet-Dark OK
INFO[0015] icon-theme: BeautyLine OK
INFO[0015] cursor-theme: Sweet-cursors OK
INFO[0015] cursor-size: 24 OK
INFO[0015] font-name: Fira Sans, 10 OK
INFO[0015] font-hinting: slight OK
INFO[0015] font-antialiasing: grayscale OK
INFO[0015] font-rgba-order: rgb OK
INFO[0015] text-scaling-factor: 1 OK
INFO[0015] toolbar-style: text OK
INFO[0015] toolbar-icons-size: large OK
INFO[0015] color-scheme: prefer-dark OK
INFO[0015] >> org.gnome.desktop.sound
INFO[0015] event-sounds: true OK
INFO[0016] input-feedback-sounds: false OK
INFO[0016] >>> Backing up gsettings to /home/stamina/.local/share/nwg-look
INFO[0016] >>> Exporting /home/stamina/.config/gtk-3.0/settings.ini
INFO[0016] >>> Exporting /etc/gtk-2.0/gtkrc:/home/stamina/.gtkrc-2.0:/home/stamina/.config/gtkrc-2.0
WARN[0016] Failed creating file: open /etc/gtk-2.0/gtkrc:/home/stamina/.gtkrc-2.0:/home/stamina/.config/gtkrc-2.0: no such file or directory
INFO[0016] >>> Exporting /home/stamina/.local/share/icons/default/index.theme
INFO[0016] >>> Exporting /home/stamina/.config/xsettingsd/xsettingsd.conf
Hello darkness my old friend!!!
nwg-look
INFO[0000] >>> Loading preferences
INFO[0000] lang: en_US
INFO[0000] >>> Parsing original /home/sgs/.config/gtk-3.0/settings.ini
INFO[0000] gtk-theme: Sweet-Dark
INFO[0000] cursor-theme: BeautyLine
INFO[0027] >>> Applying gsettings
INFO[0027] >> org.gnome.desktop.interface
INFO[0027] gtk-theme: Sweet-Dark OK
INFO[0027] icon-theme: BeautyLine OK
INFO[0027] cursor-theme: BeautyLine OK
INFO[0027] cursor-size: 24 OK
INFO[0027] font-name: Fira Sans, 10 OK
INFO[0027] font-hinting: slight OK
INFO[0027] font-antialiasing: grayscale OK
INFO[0027] font-rgba-order: rgb OK
INFO[0027] text-scaling-factor: 1 OK
INFO[0027] toolbar-style: text OK
INFO[0027] toolbar-icons-size: large OK
INFO[0027] color-scheme: prefer-dark OK
INFO[0027] >> org.gnome.desktop.sound
INFO[0027] event-sounds: true OK
INFO[0027] input-feedback-sounds: false OK
INFO[0027] >>> Backing up gsettings to /home/sgs/.local/share/nwg-look
INFO[0027] >>> Exporting /home/sgs/.config/gtk-3.0/settings.ini
INFO[0027] >>> Exporting /etc/gtk-2.0/gtkrc:/home/sgs/.gtkrc-2.0:/home/sgs/.config/gtkrc-2.0
WARN[0027] Failed creating file: open /etc/gtk-2.0/gtkrc:/home/sgs/.gtkrc-2.0:/home/sgs/.config/gtkrc-2.0: no such file or directory
INFO[0027] >>> Exporting /home/sgs/.icons/default/index.theme
INFO[0027] >>> Exporting /home/sgs/.config/xsettingsd/xsettingsd.conf
IDK, file exist
â•─sgs@bit in ~/.config as đź§™
╰─λ ls | grep gtk
drwxr-xr-x - sgs 30 Okt 12:58 gtk-3.0
drwxr-xr-x - sgs 30 Okt 12:58 gtk-4.0
.rw-r--r-- 52 sgs 30 Okt 12:58 gtkrc
.rw-r--r-- 87 sgs 30 Okt 12:58 gtkrc-2.0
I mark it solved.
Sorry, I didn’t specify it, but nah, it was in KDEs System Settings > Colours & Themes > Application Style > “Configure GNOME/GTK Application Style” button in upper right corner (may have to click the “︙” button or expand window horizontally for it to become visible)
Thanks , I now know my way around Garuda just a little bit better!
