Dracut issue
Hello,
there was just an update of dracut (059-1) and since I get this
sudo dracut -f
dracut: Executing: /usr/bin/dracut -f
dracut: Can't write to /boot/efi/83d5b5c7136742518b8bf6cdd0c5a998/6.4.2-zen1-1-zen: Directory /boot/efi/83d5b5c7136742518b8bf6cdd0c5a998/6.4.2-zen1-1-zen does not exist or is not accessible.
This subfolder doesn't exist indeed, but there was no error before this upgrade.
Any idea?
Thanks.
Installing garuda-bootctl-dracut solved the issue.
Are you using systemd-boot?
Oops, I believe that package never made it out of development and should be considered abandoned:
This command is not specific enough to be run as-is on a Garuda LInux system. At the very least, you would need to add arguments for the path of the initramfs, and the naming convention it should follow.
Garuda Linux has a special command for rebuilding the initramfs, which is tied in to a bunch of custom hooks and scripts:
sudo dracut-rebuild
I am using grub as a bootloader.
I reinstalled garuda-dracut-support and everything seems OK.
