Dr460nized theme seems to have disappeared after restarting my laptop
This morning after starting my laptop all the Dr460nized theming had disappeared. The login screen looked the same as before with the Dr460nized theme still in place but after entering my password and logging in, the KDE plasma logo was shown while the desktop was loading and then once it loaded, the desktop displayed things with the KDE’s default light Breeze theme. Which does not look good after using the Dr460nized theme for the past 2.5 years. There is no bar at the top with access to the applications menu or displaying system tray notifications and the clock. Everything is displayed on a single task bar at the bottom of the screen reminiscent of windows. All applications that I tested are loading in the light Breeze theme.
The last update I had done was on the 19th September 2024. So this was well before the time when I shut the computer down (last night) and then restarted this morning. I did do a system update after booting up today to see if that fixed the problem but that didn’t help.
I then tried rebooting and loading an earlier snapshot to see if the desktop would display properly with an old snapshot. However every snapshot failed to boot with the following errors as the last messages in the boot screen:
[FAILED] Failed to start Samba NMB Daemon
[FAILED] Failed to start Samba SMB Daemon
I also tried to boot with recovery mode using the current install/version of everything. When I tried this the boot failed with the following output.
:: running hook [encrypt]
Waiting 10 seconds for device /dev/disk/by-uuid/albdb4fa-5e43-4a39-a118-b7c752866993 ...
:: running hook [openswap]
mount: bad usage
Try 'mount --help' for more information.
Failed to open key file.
unmount: openswap_keymount: not mounted.
:: running hook [resume]
No resume device found, exiting.
:: mounting 'UUID=albdb4fa-5e43-4a39-a118-b7c752866993' on real root
mount: /new_root: can't find UUID=albdb4fa-5e43-4a39-a118-b7c752866993.
:: running emergency hook [plymouth]
ERROR: Failed to mount 'UUID=albdb4fa-5e43-4a39-a118-b7c752866993' on real root
You are now being dropped into an emergency shell.
sh: can't access tty; job control turned off
[rootfs ~]#
As a side note after that restart the browsing history and tab set up for my chromium based browsers seems to have disappeared although bookmarks and extensions are still there. And my emacs init file seems to have disappeared. I have a back up of the init file but it seems so strange that it is no longer in the .emacs/d folder.
The following is the output of the garuda-inxi command:
  Kernel: 6.11.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=a1bdb4fa-5e43-4a39-a118-b7c752866993 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=f791f7a6-8ae8-405e-a318-e34e9ec36c9a:luks-f791f7a6-8ae8-405e-a318-e34e9ec36c9a
    root=/dev/mapper/luks-f791f7a6-8ae8-405e-a318-e34e9ec36c9a quiet
    resume=/dev/mapper/luks-c8d410ed-719a-461c-a5d6-711a56a8ca96 loglevel=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
  Type: Laptop System: Acer product: Nitro AN515-45 v: V1.08
  Mobo: CZ model: Scala_CAS v: V1.08 serial: <superuser required>
    part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.08
    date: 07/21/2021
  ID-1: BAT1 charge: 47.2 Wh (100.0%) condition: 47.2/58.8 Wh (80.3%)
    volts: 16.8 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
    status: full
    microcode: 0xA50000C
  Speed (MHz): avg: 400 min/max: 400/4463 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 400
    4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
    14: 400 15: 400 16: 400 bogomips: 102206
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Acer Incorporated ALI driver: nvidia v: 560.35.03
    alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
    2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: none empty: HDMI-A-1
    bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: Acer Incorporated ALI driver: amdgpu
    v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
    active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1638
    class-ID: 0300 temp: 44.0 C
  Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0408:a061
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: radeonsi
    gpu: nvidia,amdgpu display-ID: 0
    drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
    drv: radeonsi inactive: device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.1
    renoir LLVM 18.1.8 DRM 3.59 6.11.2-zen1-1-zen) device-ID: 1002:1638
  API: Vulkan v: 1.3.295 layers: 14 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.4-arch1.1
    device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1
    type: discrete-gpu name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia
    v: 560.35.03 device-ID: 10de:2520 surfaces: xcb,xlib,wayland device: 2
    v: 24.2.4-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: NVIDIA GA106 High Definition Audio vendor: Acer Incorporated ALI
    vendor: Acer Incorporated ALI driver: N/A alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
  API: ALSA v: k6.11.2-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 03:00.0 chip-ID: 10ec:2600 class-ID: 0200
    vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04ca:3802
  Local Storage: total: 1.38 TiB used: 802.76 GiB (57.0%)
    fw-rev: FXM7201Q temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
  ID-1: / raw-size: 914.66 GiB size: 914.66 GiB (100.00%)
    used: 802.76 GiB (87.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-f791f7a6-8ae8-405e-a318-e34e9ec36c9a
    used: 728 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 914.66 GiB size: 914.66 GiB (100.00%)
  ID-4: /var/log raw-size: 914.66 GiB size: 914.66 GiB (100.00%)
  ID-5: /var/tmp raw-size: 914.66 GiB size: 914.66 GiB (100.00%)
  ID-1: swap-1 type: zram size: 14.98 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 16.55 GiB used: 0 KiB (0.0%)
    mapped: luks-c8d410ed-719a-461c-a5d6-711a56a8ca96
  System Temperatures: cpu: 56.8 C mobo: 48.0 C gpu: amdgpu temp: 44.0 C
  Memory: total: 16 GiB note: est. available: 14.98 GiB used: 5.78 GiB (38.6%)
  Processes: 401 Power: uptime: 1h 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.95 GiB services: org_kde_powerdevil,upowerd
  Packages: pm: pacman pkgs: 2522 libs: 641 tools: octopi,paru Compilers:
    clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
  System install date:     2022-06-26
  Last full system update: 2024-10-06
Cheers,
John
Try
lookandfeeltool --resetLayout --apply Dr460nized
Log out and back in.
That did the trick.
Thank you so much! :smile:
Hey, welcome to the forum!
