❯ paru -S plasma5-themes-sweet-full-git
:: plasma5-themes-sweet-full-git is in IgnorePkg/IgnoreGroup. Install anyway? [Y/n]
resolving dependencies…
looking for conflicting packages…
warning: insufficient columns available for table display
Packages (1) plasma5-themes-sweet-full-git-r390.48a9050-1
Total Download Size: 2.97 MiB
Total Installed Size: 9.61 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages…
plasma5-themes-sweet-fu… 3.0 MiB 10.2 MiB/s 00:00 [------------------------------] 100%
(1/1) checking keys in keyring [------------------------------] 100%
(1/1) checking package integrity [------------------------------] 100%
:: File /var/cache/pacman/pkg/plasma5-themes-sweet-full-git-r390.48a9050-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (checksum)).
Do you want to delete it? [Y/n] Y
error: failed to commit transaction (invalid or corrupted package (checksum))
:: plasma5-themes-sweet-full-git is in IgnorePkg/IgnoreGroup. Install anyway? [Y/n] Y
plasma5-themes-sweet-fu… 3.0 MiB 9.77 MiB/s 00:00 [------------------------------] 100%
First you should remove it from ignore pkgs then. As said here,
manually reinstall it so paru -R plasma5-themes-sweet-full-git then paru -S plasma5-themes-sweet-full-git or paru plasma5-themes-sweet-full-git an you should be good to go.
If only it was so simple as pressing Y… Gives this -
╰─λ paru -R plasma5-themes-sweet-full-git
checking dependencies...
:: removing plasma5-themes-sweet-full-git breaks dependency 'plasma5-themes-sweet-full-git' required by garuda
-dr460nized
If we could remove it, we could then re-install it. Pacman, Paru, the un-loved Octopi all return the same messages.
Even manually removing the package from the cache beforehand gives the same message. Once it is downloaded it reports the package as corrupted. I even tried changing the SigLevel in pacman.conf to TrustAll but to no avail. Is there a way of removing it despite the Dr460nized dependancy?
This is on Plasma5 KDE Dr460nized, the update worked fine on 2 Hyprland Installs.
Thanks for the reply FGD. I have tried many variations. Updating it, removing it & catching the download to install manually. I fully understand the Pacman, Paru, Yay and Octopi switches.
None of my attempts work.
I always get the ‘Corrupted Package’ Error.
It has, however, worked flawlessly on two Hyprland installs and a forth PC.
Yes, the ‘Bump’ fixed it for me too.
It did fail the first time with ‘File already exists’ but I fixed that by using using the ’ --overwrite “*” ’ switch.
