Dolphin does not accept change of color scheme
Hey there,
I'm trying to change the default color scheme in Garuda. The settings menu seems to accept the change, but Dolphin does not.
As I'm a new user and can't upload images - I will try to explain this a bit further. For example, if I change the color scheme from Sweetified to KvSimplicityDarkLight the settings menu will appear with the new selected color scheme, but Dolphin explorer will stay with the default Sweetified.
Here is my garuda-inxi:
Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=4a7ff64d-e97a-4a05-8c53-83e82f4c9142 rw rootflags=subvol=@
quiet rd.luks.uuid=894304ae-88a1-49ef-a955-74470cbd0253 quiet
rd.luks.uuid=663dcb41-ed62-432a-b7c9-8e7f5f5696ef
resume=/dev/mapper/luks-663dcb41-ed62-432a-b7c9-8e7f5f5696ef loglevel=3
Type: Desktop Mobo: Micro-Star model: X370 GAMING PRO CARBON (MS-7A32)
v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 1.H0
date: 07/27/2018
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3468 high: 4199 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3904
3: 2742 4: 3700 5: 3700 6: 2712 7: 4188 8: 4199 9: 2636 10: 3700 11: 3700
12: 3700 13: 2593 14: 2926 15: 3700 16: 3700 bogomips: 118388
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: ASUSTeK driver: nvidia
v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 1d:00.0 chip-ID: 10de:1b82 class-ID: 0300
Device-2: Sunplus Innovation FHD Camera Microphone
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-2.2.1:4 chip-ID: 1bcf:28c4 class-ID: 0102
Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.40x13.46")
s-diag: 1252mm (49.28")
Monitor-1: HDMI-0 pos: primary,left res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: HDMI-1 pos: right res: 2560x1440 dpi: 109
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce GTX 1070
Ti/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 1d:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 1f:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Sunplus Innovation FHD Camera Microphone
Device-4: ROCCAT Elo 7.1 Air driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.2.2:5
chip-ID: 1e7d:3a37 class-ID: 0300 serial: <filter>
API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 17:00.0
Device-2: Microsoft Xbox 360 Wireless Adapter driver: xpad type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:2 chip-ID: 045e:0719
class-ID: ff00 serial: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
Local Storage: total: 1.59 TiB used: 61.08 GiB (3.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXE7 temp: 50.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
tech: SSD serial: <filter> fw-rev: BB6Q scheme: GPT
model: WD10EZEX-00BN5A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
used: 28.85 GiB (6.7%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-894304ae-88a1-49ef-a955-74470cbd0253
ID-3: /home raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-4: /var/log raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
mapped: luks-663dcb41-ed62-432a-b7c9-8e7f5f5696ef
ID-2: swap-2 type: zram size: 31.29 GiB used: 357.2 MiB (1.1%)
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 53 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 403 Uptime: 1h 1m wakeups: 0 Memory: available: 31.29 GiB
used: 5.32 GiB (17.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1689
libs: 434 tools: octopi,paru,yay Shell: fish v: 3.6.1 running-in: konsole
inxi: 3.3.27
System install date:     2023-07-10
Last full system update: 2023-07-10
Thats likely because Kvantum is used to provide theming. Try setting it to Breeze and see what happens.
Welcome to the forum! :slight_smile:
Unfortunately, that didn't work :slight_smile:
I have tried to set global design to Breeze (appearance and work surfaces / window layout) but even after starting a new session, the Dolphin scheme is the default from Dr460nized. Is there something I'm missing?
So this is definitely set to Breeze?
Ahh nvm - I thought global design would override all settings, I haven't set application style specific to Breeze. Now it's working as expected - thank you a lot :slight_smile:
