I connected my phone to PC via KDE Connent and configured a storage location in my phone KDE Connect plugins settings. Now, when I open my device in dolphin, it says Error when accessing filesystem. sshfs finished with exit code 1
Some facts:
- system already updated (
$ paru
) - the problem is reproduced with any system users
- the problem is reproduced with any phone
- Someone has same trouble (Telegram: Contact @garudalinux)
$ inxi -Faz
, of course:
System: Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=127a3604-5d53-4bca-875e-25c515e9a1c1 rw [email protected] quiet
cryptdevice=UUID=e539b6ae-5390-4df3-9768-9292e65a0eb8:luks-e539b6ae-5390-4df3-9768-9292e65a0eb8
root=/dev/mapper/luks-e539b6ae-5390-4df3-9768-9292e65a0eb8 splash
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: K53SC v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K53SC v: 1.0 serial: <filter> BIOS: American Megatrends
v: K53SC.216 date: 09/26/2011
Battery: ID-1: BAT0 charge: 31.9 Wh (84.8%) condition: 37.6/58.3 Wh (64.4%) volts: 12.3
min: 10.8 model: [MKF_CUSTOMER] [MKF_BASEBOARD_ID] type: Li-ion serial: N/A
status: Charging
CPU: Info: Quad Core model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 2A (42) stepping: 7 microcode: 1A cache: L2: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 35122
Speed: 1408 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 1408 2: 2195 3: 2195
4: 1417 5: 2195 6: 2195 7: 2195 8: 1808
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116
Device-2: NVIDIA GF119M [GeForce GT 520MX] vendor: ASUSTeK driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:1051 class-ID: 0300
Device-3: Alcor Micro Asus Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.2:4 chip-ID: 058f:a014 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 21.2.3
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NB037H 802.11bgn driver: ath9k v: kernel port: d000
bus-ID: 03:00.0 chip-ID: 168c:002b class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: 9000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.1:6 chip-ID: 0cf3:3005 class-ID: e001
Report: bt-adapter ID: hci1 rfk-id: 4 state: down bt-service: enabled,running
Device-2: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 2-1.2:3
chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 5 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 223.57 GiB used: 43.19 GiB (19.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 052 scheme: MBR
Partition: ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 43.19 GiB (19.3%)
mapped: luks-e539b6ae-5390-4df3-9768-9292e65a0eb8
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 43.19 GiB (19.3%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 43.19 GiB (19.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 445.7 MiB (5.7%) priority: 100
Sensors: System Temperatures: cpu: 57.0 C mobo: N/A gpu: nouveau temp: 46.0 C
Info: Processes: 290 Uptime: 2h 18m wakeups: 5 Memory: 7.67 GiB used: 3.8 GiB (49.5%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1448 lib: 450 Shell: Zsh v: 5.8 running-in: tilix inxi: 3.3.06
