Docks missing after install and scroll wheel not working in Rani
I booted into Garuda from a usb drive and the docks were there, both app dock at bottom and the top bar. After the intall and restart they disappear. Googling to me to install latte-dock, but I couldnt get that to install. New to arch and just vaguely familiar with some linux distros
Welcome to the community. :slight_smile:
Please post your garuda-inxi as requested by the template.
I assume you’re using KDE Plasma. Have you tried switching to the default theme (Breeze) and then back again?
Latte Dock has been dead for a long time, so you shouldn’t try to install it.
As for the scroll issue in Rani, there’s already a thread about it:
ONE issue per topic, please.
Ok, i have no graphical way to find my snapshots of the screen or open a browser on the garuda machine. I will work on getting those sorted and posted. Thank you
Which Garuda edition do you have installed?
If you are using KDE Plasma as your desktop environment, use Meta + E to open dolphin.
Use Ctrl + Alt + T to open the console and enter
firedragon
to open the browser.
I got that figured out and took screen shots of inxi but cant upload due to being new user.
To avoid spam and other nonsense, new users are not allowed to post pictures. You can use an external pic hoster for this.
And please, no pictures from the terminal - copy the output from garuda-inxi, open the browser via the terminal, log into the forum, and paste it here as a code block. Or you can use this
garuda-inxi | tb
in the terminal and post the link.
And please answer all questions:
Garuda Dr460nized, sorry I hadnt included it. Below is my inxi output.
type or paste c╰─λ garuda-inxi
Kernel: 6.16.8-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=d91c81a7-15e3-4e2a-8e03-1453a577c629 rw rootflags=subvol=@
quiet loglevel=3
Type: Laptop System: Notebook product: NP5x_6x_7x_SNx v: N/A
serial: <superuser required> Chassis: No Enclosure type: 10
Mobo: Notebook model: NP5x_6x_7x_SNx serial: <superuser required>
uuid: <superuser required> UEFI: INSYDE v: 1.07.16LS1 date: 05/17/2023
ID-1: BAT0 charge: 56.3 Wh (100%) condition: 56.3/70.1 Wh (80.4%)
volts: 16.66 min: 15.4 model: Notebook BAT type: Li-ion serial: <filter>
charging: status: full cycles: N/A
Info: model: 13th Gen Intel Core i9-13900HX bits: 64 type: MST AMCP
microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 612 min/max: 800/5200:5400:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 612 2: 612 3: 612 4: 612
5: 612 6: 612 7: 612 8: 612 9: 612 10: 612 11: 612 12: 612 13: 612 14: 612
15: 612 16: 612 17: 612 18: 612 19: 612 20: 612 21: 612 22: 612 23: 612
24: 612 25: 612 26: 612 27: 612 28: 612 29: 612 30: 612 31: 612 32: 612
bogomips: 154828
Device-1: Intel Raptor Lake-S UHD Graphics vendor: CLEVO/KAPOK driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: eDP-2 empty: DP-2, DP-3, DP-4, HDMI-A-2, HDMI-A-3, HDMI-A-4
bus-ID: 00:02.0 chip-ID: 8086:a788 class-ID: 0300
Device-2: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile]
vendor: CLEVO/KAPOK driver: nvidia v: 580.82.09
alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 empty: DP-1,eDP-1
bus-ID: 01:00.0 chip-ID: 10de:2820 class-ID: 0300
Device-3: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:3 chip-ID: 5986:9102
class-ID: 0e02
alternate: fbdev,intel,nouveau,nv,vesa dri: iris
gpu: i915,nv_platform,nvidia,nvidia-nvswitch d-rect: 1920x1080
display-ID: 0
Monitor-1: HDMI-A-1 pos: primary model: MSI MP253 serial: <filter>
built: 2024 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 90 gamma: 1.2
size: 540x310mm (21.26x12.2") diag: 623mm (24.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: eDP-2 pos: primary model: BOE Display 0x09ee built: 2020 res:
mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 128 gamma: 1.2
size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9
modes: 1920x1080
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a788 memory: 30.31 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 11 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 25.2.4-arch1.1
device-ID: 8086:a788 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 4070 Laptop GPU driver: nvidia v: 580.82.09
device-ID: 10de:2820 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.4-arch1.1 (LLVM
de: kscreen-console,kscreen-doctor gpu: corectrl,nvidia-smi wl: wayland-info
Device-1: Intel Raptor Lake High Definition Audio vendor: CLEVO/KAPOK
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0401
Device-2: NVIDIA AD106M High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:22bd class-ID: 0403
API: ALSA v: k6.16.8-zen3-1-zen status: kernel-api with: aoss
Device-1: Intel Raptor Lake-S PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
Device-2: Intel vendor: CLEVO/KAPOK driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:0dc8 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0033
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 3.18 TiB used: 8.96 GiB (0.3%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 44.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7 Shield
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: MBR
ID-1: / raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
used: 8.95 GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
ID-4: /var/log raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
ID-5: /var/tmp raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.04 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.8 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.04 GiB used: 3.39 GiB (10.9%)
Processes: 479 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.35 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1741 libs: 517 tools: octopi,paru Compilers:
clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.1
Garuda (2.11.1-1):
System install date:     2025-10-07
Garuda release:          251002
Last full system update: 2025-10-07
Relevant software:       snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard
23/24 checks run in 0.75 seconds ⌛
Powered by garuda-health 🦅
ode here
First, open the terminal and run a system update:
garuda-update
When that is complete, reboot:
reboot
If you still do not have any panels, try resetting the theme:
lookandfeeltool --resetLayout --apply Dr460nized
and then reboot again.
Resetting the Layout fixed it. Thank you
