Dkms not required by any package by default
Hello,
I just installed the virtualbox package through Octopi and then uninstalled it (also through Octopi).
During uninstallation, Octopi suggested to uninstall dkms.
I’m not really knowledgeable about all the kernel modules but I think dkms is required for the system and the updates right?
If that the case, maybe something should “require” dkms by default so it is not suggested to uninstall it?
Kind regards,
I think it totally depends on what you have installed. I have no free-floating kernel modules on my desktop, however, my server has zfs installed.
To get a list of packages installed as dependencies but no longer required by any installed package, see #Removing unused packages (orphans).
Or use
cleanup
in terminal.
Use only pacman in terminal, not octopi :slight_smile:
Oh okay, I understood that the GPU drivers require kernel modules, which would be built/installed using dkms. For example when the kernel is updated?
But maybe it doesn’t use dkms actually!
@SGS (replied at the same time)
Are you talking about this: How to remove packages and eventually debloat the system? | Garuda Linux wiki
I thought Octopi was kinda “supported” by Garuda? Should it be avoided?
EDIT: Found this too? https://www.youtube.com/watch?v=V7kzZ45Gck8
You don’t need dkms if you aren’t using any DKMS packages.
pactree -r dkms
There is no garuda-inxi posted so we cannot make any guesses about what specific hardware you have that might use DKMS packages, but commonly DKMS packages are used to allow installing proprietary or out-or-kernel drivers on a non-standard kernel (basically any kernel other than the standard Linux kernel).
For example, if you have Nvidia or Broadcom hardware and want to use the Zen kernel, you can install the kernel headers and use the DKMS versions of the driver packages.
You can learn more about DKMS here: Dynamic Kernel Module Support - ArchWiki
Hello,
Initially I posted on feedback, with no template.
But here is the garuda-inxi if it’s still any interest to you:
Kernel: 6.10.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f22a06c1-1697-4e77-a64d-c7c3677134ba rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx
serial: <filter> part-nu: SKU uuid: 4017f533-7992-7b14-4800-c87f54534e2f
UEFI: American Megatrends v: 3014 date: 07/17/2024
Info: model: AMD Ryzen 9 7900 socket: AM5 bits: 64 type: MT MCP MCM
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 dies: 2 smt: enabled
cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 5056 high: 5270 min/max: 545/5435 base/boost: 3700/5450
scaling: driver: amd-pstate-epp governor: performance volts: 1.3 V
ext-clock: 100 MHz cores: 1: 4822 2: 5156 3: 5167 4: 5170 5: 5143 6: 5270
7: 5071 8: 5136 9: 5149 10: 4137 11: 5144 12: 5127 13: 5141 14: 5101
15: 5026 16: 5175 17: 5122 18: 5175 19: 5114 20: 4914 21: 5017 22: 4949
23: 5062 24: 5069 bogomips: 177597
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire NITRO+ driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2, HDMI-A-1, HDMI-A-2, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-1 model: Dell AW3418DW serial: <filter> built: 2017
res: 3440x1440 hz: 120 dpi: 109 gamma: 1.2 size: 798x335mm (31.42x13.19")
diag: 865mm (34.1") modes: max: 3440x1440 min: 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
navi31 LLVM 18.1.8 DRM 3.57 6.10.5-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.6-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.6-arch1.1 (LLVM
Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
Device-3: Logitech G733 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 5-2.1.3:7 chip-ID: 046d:0ab5 class-ID: 0300
Device-4: Razer USA Nommo Chroma driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.3:4
chip-ID: 1532:0517 class-ID: 0102
API: ALSA v: k6.10.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: n/a (root, process) with:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
lanes: 1 bus-ID: 08:00.0 chip-ID: 14c3:0616 class-ID: 0280
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7
chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Local Storage: total: 1.82 TiB used: 439.38 GiB (23.6%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620361WD temp: 60.9 C scheme: GPT
SMART: yes health: PASSED on: 7d 10h cycles: 44
read-units: 3,591,785 [1.83 TB] written-units: 6,566,783 [3.36 TB]
ID-1: / raw-size: 750 GiB size: 750 GiB (100.00%) used: 439.35 GiB (58.6%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5
used: 27 MiB (28.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 750 GiB size: 750 GiB (100.00%)
used: 439.35 GiB (58.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /var/log raw-size: 750 GiB size: 750 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 750 GiB size: 750 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 62.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 83.9 C mobo: 54.0 C gpu: amdgpu temp: 69.0 C
mem: 74.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 661
Memory: total: 64 GiB note: est. available: 62.44 GiB used: 13.2 GiB (21.1%)
Processes: 495 Power: uptime: 1h 53m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.96 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1840 libs: 564 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.32 running-in: konsole inxi: 3.3.35
System install date:     2024-08-03
Last full system update: 2024-08-18
Windows dual boot:       Yes
Thank you for your explanations, I wrongfully thought that it was required for all kernels.
