Distrobox not working correctly
Trying to run a distro, I get Error response from daemon: path /sys is mounted on /sys but it is not a shared or slave mount
To Reproduce
  • sudo pacman -S distrobox
  • (Maybe have docker and docker desktop installed)
  • distrobox create -i ubuntu:23.04 --name ubuntu.
  • distrobox enter ubuntu- This returned error
    Error response from daemon: Mounts denied: The path /tmp is not shared from the host and is not known to Docker. You can configure shared paths from Docker -> Preferences... -> Resources -> File Sharing. See https://docs.docker.com/ for more info. Error: failed to start containers: ubuntu
  • Add /tmp to file sharing resources via docker desktop
  • running it again, error:Error response from daemon: path /sys is mounted on /sys but it is not a shared or slave mount Error: failed to start containers: ubuntu
after that I tried adding /sys via docker desktop and doing sudo mount --make-shared /sys (based on this gh issue ) but neither helped
Expected behavior
it enters
Logs
+ '[' -z ubuntu ']'
+ '[' '!' -t 0 ']'
+ '[' '!' -t 1 ']'
+ case "${container_manager}" in
+ command -v podman
+ command -v podman-launcher
+ command -v docker
+ container_manager=docker
+ command -v docker
+ '[' 1 -ne 0 ']'
+ container_manager='docker --log-level debug'
+ '[' 0 -ne 0 ']'
+ container_home=/home/djkato
+ container_path=/home/djkato/.local/bin:/home/djkato/.bun/bin:/home/djkato/.local/share/bob/nvim-bin:/home/djkato/.cargo/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/var/lib/flatpak/exports/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/usr/lib/rustup/bin
+ '[' 0 -ne 0 ']'
+ container_status=unknown
++ docker --log-level debug inspect --type container --format 'container_status={{.State.Status}};
{{range .Config.Env}}{{if slice . 0 5 | eq "HOME="}}container_home={{slice . 5 | printf "%q"}};{{end}}{{end}}
{{range .Config.Env}}{{if slice . 0 5 | eq "PATH="}}container_path={{slice . 5 | printf "%q"}}{{end}}{{end}}' ubuntu
+ eval 'container_status=created;
container_home="/home/djkato";
container_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"'
++ container_status=created
++ container_home=/home/djkato
++ container_path=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
+ '[' created = unknown ']'
+ '[' created '!=' running ']'
+ docker --log-level debug start ubuntu
+ cleanup
+ rm -f /home/djkato/.cache/.ubuntu.fifo
+ '[' -n '' ']'
+ '[' 1 -eq 1 ']'
+ docker --log-level debug logs ubuntu
No docker logs present, docker only throws (HTTP code 500) server error - Cannot restart container 1ba1c8eee52abb92f1ecd25690e6517ecf6ccf4f394cd7c7d53bee78e398be52: path /sys is mounted on /sys but it is not a shared or slave mount
docker desktop: 4.26.1, engine: 24.0.7
inxi:
  Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=b8196f39-e08b-4bce-b75d-343098561547 rw rootflags=subvol=@
    resume=UUID=9bac1011-b1fa-4c26-85c0-a8dacd8e1df1 loglevel=3
    clearcpuid=304 ibt=off
    v: 5.115.0 wm: kwin_x11 with: Docker vt: 2 dm: SDDM Distro: Garuda
  Mobo: ASUSTeK model: PRIME B650-PLUS v: Rev 1.xx
    UEFI: American Megatrends v: 1636 date: 07/28/2023
  Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
    level: v3 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3684 high: 5396 min/max: 400/5573 scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 5349 2: 5351 3: 5346
    4: 400 5: 400 6: 5350 7: 5346 8: 400 9: 5318 10: 4484 11: 4818 12: 400
    13: 4844 14: 5347 15: 5396 16: 400 bogomips: 143985
    driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm)
    built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:731f
  Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4,HDMI-A-2
    bus-ID: 0e:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 49.0 C
    s-diag: 1245mm (49.01")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-left
    model: AOC Q3279WG5B serial: <filter> built: 2017 res: 2560x1440 dpi: 90
    gamma: 1.2 size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9
    modes: max: 2560x1440 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-r model: BenQ GW2470
    serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.1-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
    navi10 LLVM 16.0.6 DRM 3.57 6.7.4-zen1-1-zen) device-ID: 1002:731f
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.3.276 layers: 9 device: 0 type: discrete-gpu
    name: AMD Radeon RX 5700 XT driver: amd v: (AMD proprietary shader compiler)
    device-ID: 1002:731f surfaces: xcb,xlib device: 1 type: discrete-gpu
    name: AMD Radeon RX 5700 XT (RADV NAVI10) driver: mesa radv
    v: 24.0.1-arch1.1 device-ID: 1002:731f surfaces: xcb,xlib device: 2
    type: integrated-gpu name: AMD Radeon Graphics driver: amd v: (AMD
    proprietary shader compiler) device-ID: 1002:164e surfaces: xcb,xlib
    device: 3 type: integrated-gpu name: AMD Radeon Graphics (RADV
    RAPHAEL_MENDOCINO) driver: mesa radv v: 24.0.1-arch1.1
    device-ID: 1002:164e surfaces: xcb,xlib device: 4 type: cpu name: llvmpipe
    (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
    bus-ID: 0e:00.1 chip-ID: 1002:1640 class-ID: 0403
    bus-ID: 0e:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: USB MIDI Interface driver: snd-usb-audio type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: fc02:0101
    class-ID: 0103
  Device-5: Native Instruments Komplete Audio 2 driver: snd-usb-audio
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
    chip-ID: 17cc:1840 class-ID: fe01 serial: <filter>
  Device-6: PreSonus Audio Studio 1824c driver: snd-usb-audio type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:13
    chip-ID: 194f:010d class-ID: fe01 serial: <filter>
  API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0a:00.0
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
  Local Storage: total: 1.82 TiB used: 1.55 TiB (85.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P5PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 49.9 C
  ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 1.55 TiB (87.0%)
    used: 1.55 TiB (87.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 30.5 GiB used: 294 MiB (0.9%) priority: 100
  ID-2: swap-2 type: partition size: 33.55 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 60.1 C mobo: N/A
  GPU: device: amdgpu temp: 48.0 C device: amdgpu temp: 49.0 C mem: 62.0 C
    fan: 0 watts: 47.00
  Memory: total: 32 GiB note: est. available: 30.5 GiB used: 14.85 GiB (48.7%)
  Processes: 506 Power: uptime: 2h 20m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,upowerd
  Packages: 1938 pm: dpkg pkgs: 1 pm: pacman pkgs: 1925 libs: 501
    tools: octopi,paru,yay pm: pkg pkgs: 0 pm: flatpak pkgs: 12 Compilers:
    clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
Garuda (2.6.23-1):
  System install date:     2023-08-17
  Last full system update: 2024-02-20 ↻
  Failed units:            sesinetd.service
Can you provide your
As per the forum template
added, forgot sry
This means that a reboot is pending after the latest update.
Please do so, you never can say…
Did, no change :confused: wish it was that easy
This seems to be a problem from distrobox’s side. Downgrade to 1.6.0.1-1 and add it to ignore package’s for now.
sudo downgrade distrobox
I think this helped in combination of installing podman. I installed my app now successfully but I cannot get a gui app to run. Trying to run it gives me:
./studioone
### Warning: Failed to connect to Wayland display.
I think I am using x11(Garuda dragonized)
echo $XDG_SESSION_TYPE
x11
So why is it trying to run wayland? (I think they’re different display services)
I am not aware of studioone but maybe it has a dependency on wayland? In that case,
sudo pacman -S plasma-wayland-session
then while re-booting up from the sddm screen just below the password field you will notice a drop down menu. Click on that and select wayland and try launching your program.
If you have issues with it you can just as easily choose x11 from the same menu back again.
Guess that’s a good enough reason to switch away from x11. Thanks for your help, it finally runs :slight_smile:
