Hello.
Hello, this is my first time posting on a forum like this, so I might screw this up, but I have searched for an answer to my problem for days, and have found absolutely nothing.
So, in a nutshell, here is my problem:
I installed Garuda Linux Sway on my Dell Inspiron 15 laptop about a week ago. Everything seemed to be going smoothly, until after a few hours my screen got all messed up looking. By messed up, I mean that suddenly there were green outlines around everything. the text in my terminal, the status bar on top, a video I was watching, the tabs of my broswer, literally everything. Also, some things were flipping colors and the amount of green outlines was increasing and decreasing as I used my laptop. I had no idea what was going on, so I rebooted and then it was fine. Until, it happened again. I tried to ignore it, but it got worse, to the point that the text on my screen was unreadable due to the color distortions. Also, when I have suspended my laptop and woken it back up later, it just gets worse. I thought maybe there was a hardware issue, except that when I turn my laptopl off, just before shutting down, there is the image of the Garuda symbol with the circle lines moving around it, and that image is never distorted. Which leads me to believe that this is related to Sway in some way.
Here are the things I have tried:
- looking at my CPU and ram usage: CPU was less than 10% ram was less than 30%
- reinstalled my graphics drivers: no change
- scoured the internet: apparently nobody has this issue like ever, or maybe there is a specific word for this that I don't know??
- reinstalling all of my packages: nothing
okay, now I will post the things people put in these posts
error log:
Jan 23 12:53:35 natalie-inspiron kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Jan 23 12:53:35 natalie-inspiron kernel: dell_smm_hwmon: unable to get SMM Dell signature
Jan 23 12:53:36 natalie-inspiron wpa_supplicant[1465]: nl80211: kernel reports: Attribute failed policy validation
Jan 23 12:53:36 natalie-inspiron wpa_supplicant[1465]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Jan 23 12:53:36 natalie-inspiron wpa_supplicant[1465]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Jan 23 12:53:37 natalie-inspiron kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
Jan 23 12:54:04 natalie-inspiron kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
Jan 23 13:24:16 natalie-inspiron kernel: sched: RT throttling activated
Jan 23 16:09:39 natalie-inspiron kernel: ACPI Error: Thread 1376331392 cannot release Mutex [ECMX] acquired by thread 1368106624 (20210930/exmutex-378)
Jan 23 16:09:39 natalie-inspiron kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20210930/psparse-529)
Jan 23 16:35:46 natalie-inspiron kernel: Bluetooth: hci0: Timed out waiting for suspend events
Jan 23 16:35:46 natalie-inspiron kernel: Bluetooth: hci0: Suspend timeout bit: 9
Jan 23 16:35:46 natalie-inspiron kernel: Bluetooth: hci0: Suspend notifier action (3) failed: -110
Jan 23 16:35:46 natalie-inspiron wpa_supplicant[1465]: nl80211: kernel reports: Attribute failed policy validation
Jan 23 16:35:46 natalie-inspiron wpa_supplicant[1465]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Jan 23 16:35:46 natalie-inspiron wpa_supplicant[1465]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Jan 23 16:37:04 natalie-inspiron sudo[250749]: nattie : a password is required ; TTY=pts/0 ; PWD=/home/nattie ; USER=root ; COMMAND=/sbin/true
Jan 23 16:37:58 natalie-inspiron sudo[251627]: nattie : a password is required ; TTY=pts/0 ; PWD=/home/nattie ; USER=root ; COMMAND=/sbin/true
Jan 23 16:38:29 natalie-inspiron sudo[252785]: nattie : a password is required ; TTY=pts/0 ; PWD=/home/nattie ; USER=root ; COMMAND=/sbin/true
Jan 23 16:42:09 natalie-inspiron pipewire-pulse[2971]: mod.protocol-pulse: server 0x557e98835090: client 0x557e9894d980 [Opera] error -104 (Connection reset by peer)
Jan 23 16:48:12 natalie-inspiron sudo[266089]: nattie : a password is required ; TTY=pts/0 ; PWD=/home/nattie ; USER=root ; COMMAND=/sbin/true
Jan 23 16:48:24 natalie-inspiron sudo[266517]: nattie : a password is required ; TTY=pts/0 ; PWD=/home/nattie ; USER=root ; COMMAND=/sbin/true
Jan 23 17:40:21 natalie-inspiron systemd-coredump[339210]: Process 339208 (ly) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 55f19b5e03
a88be11e86025133bff8f8cb6bcaf3
Module libcap-ng.so.0 with build-id 345acbd3f1a251a101cd25c90bf0b3adb9f5c70e
Module ld-linux-x86-64.so.2 with build-id 040cc3dd10461562f177df39e3be2f3704258c3c
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libdl.so.2 with build-id 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Module libaudit.so.1 with build-id ba2774b7e0faa91f85f6f2e774e2cad9a9e1d550
Module libc.so.6 with build-id 4b406737057708c0e4c642345a703c47a61c73dc
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libpam.so.0 with build-id bb11b2685fe89555938ffd330ea44d82b0f8701c
Module ly with build-id 800c87d95aae3b6a455f76f6c7e9d49321db1ce5
Stack trace of thread 339208:
#0 0x0000564acc0e2f1a n/a (ly + 0xbf1a)
#1 0x0000564acc0df492 n/a (ly + 0x8492)
#2 0x0000564acc0dcbd5 n/a (ly + 0x5bd5)
#3 0x00007f3d3d3d3b25 __libc_start_main (libc.so.6 + 0x27b25)
#4 0x0000564acc0dc61e n/a (ly + 0x561e)
ELF object binary architecture: AMD x86-64
systemd analyse:
482ms grub-btrfs-snapper.service
472ms dev-nvme0n1p2.device
183ms ldconfig.service
160ms upower.service
127ms systemd-backlight@leds:dell::kbd_backlight.service
121ms dev-zram0.swap
115ms systemd-logind.service
94ms NetworkManager.service
94ms ModemManager.service
93ms polkit.service
76ms plymouth-quit-wait.service
76ms plymouth-quit.service
62ms systemd-udev-trigger.service
61ms [email protected]
60ms boot-efi.mount
57ms systemd-journal-flush.service
46ms systemd-remount-fs.service
45ms bolt.service
40ms systemd-timesyncd.service
34ms avahi-daemon.service
33ms systemd-journald.service
32ms udisks2.service
32ms bluetooth.service
30ms systemd-udevd.service
30ms lvm2-monitor.service
26ms systemd-vconsole-setup.service
25ms systemd-modules-load.service
25ms systemd-rfkill.service
24ms systemd-guest-user.service
23ms plymouth-read-write.service
23ms systemd-tmpfiles-clean.service
21ms plymouth-start.service
17ms dev-disk-by\x2duuid-8b3a96c2\x2d0a59\x2d4b76\x2d9c68\x2dfe8221931d8e.swap
17ms systemd-fsck@dev-disk-by\x2duuid-B743\x2d5E8E.service
17ms systemd-sysusers.service
17ms systemd-journal-catalog-update.service
16ms [email protected]
15ms systemd-guest-config.service
14ms home.mount
14ms root.mount
14ms systemd-tmpfiles-setup.service
13ms garuda-pacman-lock.service
13ms srv.mount
13ms [email protected]
12ms linux-modules-cleanup.service
12ms var-cache.mount
11ms var-log.mount
10ms var-tmp.mount
8ms dev-hugepages.mount
8ms [email protected]
8ms dev-mqueue.mount
8ms sys-kernel-debug.mount
8ms systemd-user-sessions.service
7ms systemd-random-seed.service
7ms sys-kernel-tracing.mount
7ms kmod-static-nodes.service
6ms systemd-binfmt.service
6ms uresourced.service
6ms systemd-sysctl.service
6ms systemd-update-utmp.service
5ms [email protected]
5ms systemd-tmpfiles-setup-dev.service
4ms rtkit-daemon.service
4ms systemd-update-done.service
4ms systemd-backlight@backlight:intel_backlight.service
3ms home-guest.mount
3ms tmp.mount
2ms wpa_supplicant.service
2ms proc-sys-fs-binfmt_misc.mount
1ms sys-kernel-config.mount
1ms sys-fs-fuse-connections.mount
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @2.951s
└─multi-user.target @2.951s
└─ModemManager.service @2.856s +94ms
└─polkit.service @2.761s +93ms
└─basic.target @2.750s
└─sockets.target @2.750s
└─dbus.socket @2.750s
└─sysinit.target @2.749s
└─systemd-update-done.service @2.744s +4ms
└─ldconfig.service @2.560s +183ms
└─local-fs.target @2.560s
└─tmp.mount @2.557s +3ms
└─swap.target @2.289s
└─dev-zram0.swap @2.167s +121ms
└─[email protected] @2.147s +16ms
└─dev-zram0.device @2.144s
system specs:
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9f83fb34-9de4-441e-b9f6-0a2dca9957f3
resume=UUID=8b3a96c2-0a59-4b76-9c68-fe8221931d8e loglevel=3
Desktop: sway 1.6.1 vt: 2 dm: Ly Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 15 5510 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: Dell model: 0KX55F v: A00 serial: <superuser required> UEFI: Dell v: 2.4.1
date: 11/05/2021
ID-1: BAT0 charge: 28.3 Wh (52.0%) condition: 54.4/54.0 Wh (100.8%) volts: 14.9 min: 15.0
model: BYD DELL WV3K814 type: Unknown serial: <filter> status: Discharging
Info: model: 11th Gen Intel Core i5-11300H bits: 64 type: MT MCP arch: Tiger Lake family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0x88
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 320 KiB
desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1405 high: 2673 min/max: 400/4400 scaling: driver: intel_pstate
governor: performance cores: 1: 1729 2: 429 3: 2673 4: 1936 5: 583 6: 1051 7: 1908 8: 938
bogomips: 41779
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 3-6:3
chip-ID: 1bcf:2a02 class-ID: 0e02 serial: <filter>
Display: wayland server: N/A compositor: sway v: 1.6.1 driver: loaded: intel,modesetting
alternate: fbdev,vesa display-ID: 1 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.3.4 direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:a0f0
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0026
Local Storage: total: 238.47 GiB used: 15.8 GiB (6.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC711 NVMe 256GB size: 238.47 GiB
rev: 41002131 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 221.26 GiB size: 221.26 GiB (100.00%) used: 15.8 GiB (7.1%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 221.26 GiB size: 221.26 GiB (100.00%) used: 15.8 GiB (7.1%) fs: btrfs
ID-4: /var/log raw-size: 221.26 GiB size: 221.26 GiB (100.00%) used: 15.8 GiB (7.1%) fs: btrfs
ID-5: /var/tmp raw-size: 221.26 GiB size: 221.26 GiB (100.00%) used: 15.8 GiB (7.1%) fs: btrfs
ID-1: swap-1 type: partition size: 16.91 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.37 GiB used: 1.2 MiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 62.0 C mobo: N/A
Processes: 299 Uptime: 4h 46m wakeups: 9141 Memory: 15.38 GiB used: 4.31 GiB (28.0%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1611
lib: 444 Client: Unknown Client: garuda-assistant inxi: 3.3.12
Is there any other stuff I should include? Please let me know, an I will add it!
I am eager to find a solution to this so my computer will stop looking ugly at random times while I am trying to work.
