Here's the log before I force rebooted
Dec 19 20:26:02 phrog-pc xdg-desktop-portal-kde[4676]: xdp-kde-background: GetAppState called: no parameters
Dec 19 20:27:33 phrog-pc systemd[1]: Started Daily Cleanup of Snapper Snapshots.
Dec 19 20:27:33 phrog-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapper>
Dec 19 20:27:33 phrog-pc kernel: audit: type=1130 audit(1639909653.278:552): pid=1 uid=0 auid=4294967295 ses=>
Dec 19 20:27:33 phrog-pc dbus-daemon[504]: [system] Activating via systemd: service name='org.opensuse.Snappe>
Dec 19 20:27:33 phrog-pc systemd[1]: Starting DBus interface for snapper...
Dec 19 20:27:33 phrog-pc dbus-daemon[504]: [system] Successfully activated service 'org.opensuse.Snapper'
Dec 19 20:27:33 phrog-pc systemd[1]: Started DBus interface for snapper.
Dec 19 20:27:33 phrog-pc kernel: audit: type=1130 audit(1639909653.399:553): pid=1 uid=0 auid=4294967295 ses=>
Dec 19 20:27:33 phrog-pc systemd-helper[5205]: running cleanup for 'root'.
Dec 19 20:27:33 phrog-pc systemd-helper[5205]: running number cleanup for 'root'.
Dec 19 20:27:33 phrog-pc systemd-helper[5205]: running timeline cleanup for 'root'.
Dec 19 20:27:33 phrog-pc systemd-helper[5205]: running empty-pre-post cleanup for 'root'.
Dec 19 20:27:33 phrog-pc systemd[1]: snapper-cleanup.service: Deactivated successfully.
Dec 19 20:27:33 phrog-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapper->
Dec 19 20:27:33 phrog-pc kernel: audit: type=1131 audit(1639909653.852:554): pid=1 uid=0 auid=4294967295 ses=>
Dec 19 20:27:43 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3428>
Dec 19 20:27:43 phrog-pc systemd[3056]: Started Konsole - Terminal.
Dec 19 20:27:43 phrog-pc konsole[5208]: Icon theme "gnome" not found.
Dec 19 20:27:52 phrog-pc dbus-daemon[3143]: [session uid=1000 pid=3143] Activating via systemd: service name=>
Dec 19 20:27:52 phrog-pc systemd[3056]: Starting Accessibility services bus...
Dec 19 20:27:52 phrog-pc dbus-daemon[3143]: [session uid=1000 pid=3143] Successfully activated service 'org.a>
Dec 19 20:27:52 phrog-pc systemd[3056]: Started Accessibility services bus.
Dec 19 20:28:33 phrog-pc systemd[1]: snapperd.service: Deactivated successfully.
Dec 19 20:28:33 phrog-pc kernel: audit: type=1131 audit(1639909713.868:555): pid=1 uid=0 auid=4294967295 ses=>
Dec 19 20:28:33 phrog-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapperd>
Dec 19 20:28:40 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5498>
Dec 19 20:28:40 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 54>
Dec 19 20:28:40 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5499>
Dec 19 20:29:03 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6124>
Dec 19 20:29:43 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6313>
Dec 19 20:32:34 phrog-pc systemd[1]: Starting Cleanup of Temporary Directories...
Dec 19 20:32:34 phrog-pc systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Dec 19 20:32:34 phrog-pc systemd[1]: Finished Cleanup of Temporary Directories.
Dec 19 20:32:34 phrog-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd>
Dec 19 20:32:34 phrog-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd->
Dec 19 20:32:34 phrog-pc kernel: audit: type=1130 audit(1639909954.675:556): pid=1 uid=0 auid=4294967295 ses=>
Dec 19 20:32:34 phrog-pc kernel: audit: type=1131 audit(1639909954.675:557): pid=1 uid=0 auid=4294967295 ses=>
Dec 19 20:38:28 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2658>
Dec 19 20:38:28 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 26>
Dec 19 20:38:29 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 27>
Dec 19 20:38:30 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28>
Dec 19 20:38:32 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3172>
Dec 19 20:38:32 phrog-pc systemd[3056]: app-org.kde.konsole-795c4b4e706e44978a50e003939c7537.scope: Consumed >
Dec 19 20:38:32 phrog-pc kwin_x11[3203]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3174>
Dec 19 20:38:59 phrog-pc kernel: NVRM: GPU at PCI:0000:01:00: GPU-1223b948-0fc6-6f40-df97-161bc3cca86a
Dec 19 20:38:59 phrog-pc kernel: NVRM: Xid (PCI:0000:01:00): 79, pid=3203, GPU has fallen off the bus.
Dec 19 20:38:59 phrog-pc kernel: NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
Dec 19 20:38:59 phrog-pc kernel: NVRM: GPU 0000:01:00.0: GPU serial number is .
Dec 19 20:38:59 phrog-pc kernel: NVRM: A GPU crash dump has been created. If possible, please run
NVRM: nvidia-bug-report.sh as root to collect this data before
NVRM: the NVIDIA kernel module is unloaded.
Dec 19 20:39:12 phrog-pc kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: >
Dec 19 20:39:17 phrog-pc kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: >
Dec 19 20:50:58 phrog-pc kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Dec 19 20:51:02 phrog-pc NetworkManager[505]: <info> [1639911062.6986] device (enp3s0): carrier: link connec>
Dec 19 20:51:02 phrog-pc NetworkManager[505]: <info> [1639911062.6987] device (enp3s0): DHCPv4 lease renewal>
Dec 19 20:51:02 phrog-pc kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
Dec 19 20:51:02 phrog-pc NetworkManager[505]: <info> [1639911062.7017] dhcp4 (enp3s0): canceled DHCP transac>
Dec 19 20:51:02 phrog-pc NetworkManager[505]: <info> [1639911062.7017] dhcp4 (enp3s0): state changed bound ->
Dec 19 20:51:02 phrog-pc NetworkManager[505]: <info> [1639911062.7020] dhcp4 (enp3s0): activation: beginning>
Dec 19 20:51:04 phrog-pc NetworkManager[505]: <info> [1639911064.7145] dhcp4 (enp3s0): state changed unknown>
Dec 19 20:51:04 phrog-pc dbus-daemon[504]: [system] Activating via systemd: service name='org.freedesktop.nm_>
Dec 19 20:51:04 phrog-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 19 20:51:04 phrog-pc dbus-daemon[504]: [system] Successfully activated service 'org.freedesktop.nm_dispat>
Dec 19 20:51:04 phrog-pc systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 19 20:51:04 phrog-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=Network>
Dec 19 20:51:04 phrog-pc kernel: audit: type=1130 audit(1639911064.723:558): pid=1 uid=0 auid=4294967295 ses=>
Dec 19 20:51:15 phrog-pc systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 19 20:51:15 phrog-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkM>
Dec 19 20:51:15 phrog-pc kernel: audit: type=1131 audit(1639911075.278:559): pid=1 uid=0 auid=4294967295 ses=>
-- Boot 3a189273e2384d92808cfebcdee6f2f1 --
Looks like my GPU is crashing? Things were still reporting while my screen was black it seems like based on the times, so why did my keyboard not work, doesn't that only happen in a kernel crash?
