Display issue
Hi im having a weird issue my specs are hp laptop with gtx 1650 and 10th gen i5 CPU i installed the nvidia DKMS drivers and everything working great but i can only get display from my external monitor the laptop monitor just shows loading kernel Linux-lts loading initial ram disk basically my external monitor working fine and drivers working fine but all i can ever see on my laptop is black screen with text saying loading Linux-lts loading initial ram disk and it just stays that way but my external monitor works idk its weird any solutions to whats happening?
Reinstall with no external monitor connected.
Please post inxi -Faz
I dont really wanna reinstall unless i just really have to already got games and stuff download and stuff installed heres the thing laptop monitor and external display both work on lts kernel withought nvidia drivers installed but when i install them only external monitor works dont even pick up my laptop display
Kernel: 5.10.56-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=f220276f-7aca-49e7-9d65-c44b99a343c7
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk1xxx v: Type1ProductConfigId
Mobo: HP model: 8742 v: 02.34 serial: <filter> UEFI: Insyde v: F.21 date: 01/08/2021
Battery:   ID-1: BAT1 charge: 51.4 Wh (100.0%) condition: 51.4/52.5 Wh (98.0%) volts: 13.1 min: 11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter> status: Full
CPU:       Info: Quad Core model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 2 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 39999
Speed: 4324 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4324 2: 4346 3: 4244 4: 4401
5: 4492 6: 4402 7: 4363 8: 4386
Graphics:  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M vendor: Hewlett-Packard driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-5:5
chip-ID: 04f2:b627 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9") s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 144 dpi: 92 size: 531x298mm (20.9x11.7") diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02
direct render: Yes
Audio:     Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-1:2 chip-ID: 0951:16a4 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.56-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 4000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 3000 bus-ID: 09:00.0 chip-ID: 10ec:c822
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-14:6
chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
RAID:      Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 6060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: class-ID: 0104
Drives:    Local Storage: total: 238.47 GiB used: 47.01 GiB (19.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 HFM256GDJTNI-82A0A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: HPS0 temp: 37.9 C scheme: GPT
Partition: ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 47.01 GiB (19.7%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 47.01 GiB (19.7%) fs: btrfs
ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 47.01 GiB (19.7%)
ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 47.01 GiB (19.7%)
ID-1: swap-1 type: zram size: 7.57 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 49.0 C mobo: 10.0 C gpu: nvidia temp: 45 C
Info:      Processes: 258 Uptime: 2m wakeups: 1 Memory: 7.57 GiB used: 2.13 GiB (28.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1691 lib: 507
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
If you include terminal outputs in your post please use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
greetings SGS
A simple solution might be (if you’re lucky) to rename-disable mhwd.conf at Xorg
/etc/X11/xorg.conf.d/
I don’t remember the exact file name, but you can read the contents.
If you need some customization for nvidia driver later, you might do the minimal, as described in Archwiki.
For info, post
xrandr | grep "connected" | cut -d" " -f "1 2"
bash -c 'for p in /sys/class/drm/*/status; do con=${p%/status}; echo -n "${con#*/card?-}: "; cat $p; done'
ls /etc/X11/xorg.conf.d/
mhwd --status
mhwd -li
bash -c 'for Xlog in $(ls /var/log/Xorg.?.log); do echo -e "\n" $Xlog ; grep -E "(EE)|(WW)|failed|Time" $Xlog ; done'
Sounds like the wiring on your laptop is problematic and you’ll need to configure Reverse PRIME, https://wiki.archlinux.org/title/PRIME#Reverse_PRIME
Or, use Garuda Settings Manager and install the hybrid profile rather than the Nvidia drivers directly so you can benefit from render offloading.
