Display Issue using both X11 and Wayland
I use 3 monitors with my PC and out of the blue only 2 will work. When I try to use Nvidia Server Settings to get third monitor to work in X11, it will ask me to save config to xorg.conf. which seems to be missing in all of my PCs and laptops running Garuda. Running Wayland doesn’t produce any positive results still down to two monitors and no options with NVidia Server settings. When using KDE to adjust monitor it produces an error. It does see the third monitor just can’t enable it.
Providing garuda-inxi:
╭─reggie@garudaK in ~
╰─λ garuda-inxi
root=UUID=d0fdb2ba-761e-49b0-a9ea-7bb74e789e50 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
UEFI: American Megatrends v: 4204 date: 02/24/2022
Device-1: hidpp_battery_0 model: Logitech M510 serial: <filter>
Device-2: hidpp_battery_1 model: Logitech K350 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3999 high: 4003 min/max: 2200/4918 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4000 2: 4000
3: 4000 4: 4000 5: 3999 6: 4000 7: 3987 8: 4000 9: 4003 10: 4000 11: 4000
12: 4000 13: 4000 14: 4000 15: 4000 16: 3998 17: 4000 18: 4000 19: 3999
20: 4000 21: 4000 22: 4000 23: 3999 24: 3996 bogomips: 191991
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: ASUSTeK
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 4
link-max: lanes: 16 ports: active: none off: DP-1,DVI-D-1,HDMI-A-1
empty: none bus-ID: 04:00.0 chip-ID: 10de:2187 class-ID: 0300
Device-2: Logitech BCC950 ConferenceCam
driver: hid-generic,usbhid,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 5-3.1:5 chip-ID: 046d:0837 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 3840x1080
display-ID: 0
Monitor-1: DP-1 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: DVI-D-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650
SUPER/PCIe/SSE2 memory: 3.91 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 SUPER driver: nvidia v: 555.58.02 device-ID: 10de:2187
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 04:00.1 chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech BCC950 ConferenceCam audio
lanes: 1 mode: 1.1 bus-ID: 5-3.3:8 chip-ID: 046d:0838 class-ID: 0300
Device-4: Walmart AB13X Headset Adapter
lanes: 1 mode: 1.1 bus-ID: 7-4.4:6 chip-ID: 001f:0b21 class-ID: 0300
API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Device-2: Intel 82571EB/82571GB Gigabit Ethernet D0/D1 driver: e1000e
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 port: f020 bus-ID: 09:00.0
chip-ID: 8086:105e class-ID: 0200
IF: enp9s0f0 state: down mac: <filter>
Device-3: Intel 82571EB/82571GB Gigabit Ethernet D0/D1 driver: e1000e
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 port: f000 bus-ID: 09:00.1
IF: enp9s0f1 state: down mac: <filter>
Device-4: Realtek RTL8152 Fast Ethernet Adapter driver: r8152 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-4.1:4
chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp11s0f3u4u1 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-3:2 chip-ID: 7392:c611
Local Storage: total: 3.64 TiB used: 553.78 GiB (14.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRD2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 553.78 GiB (29.7%)
used: 553.78 GiB (29.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.71 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.6 C mobo: N/A
Memory: total: 64 GiB note: est. available: 62.71 GiB used: 9.26 GiB (14.8%)
Processes: 511 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.04 GiB services: org_kde_powerdevil,
Packages: 2137 pm: pacman pkgs: 2105 libs: 593 tools: gnome-software,
octopi, pamac, paru pm: flatpak pkgs: 32 Compilers: clang: 18.1.8
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date:     2024-05-21
Last full system update: 2024-07-06
Does anyone have an idea on this? FYI using a laptop running Garuda without NVidia seems to work on all 3 monitors via docking station. My only other option is to reseat the cables at this point.
I was gonna ask if this was laptop.
Do you want to run 3 external monitor alongside the internal screen. So 4 screens in total?
Some HW is not very well suited for the linux platform. This seems to be varying desktop support with Nvidia GPUs. Again , depends on the goal and the model. Nvidia GPUs are claimed to work well for AI specific applications.
Why not read about Nvidia history, how and why they have been behind on the Linux desktop platform?
It might be easier to run AMD GPU. I happened to run 3 monitors at some point. Worked fine.
Or upgrade to a better supported nvidia card. Do the research and decide for yourself.
Good luck!
No desktop and laptop strictly 3 monitors, also 3 monitors were running fine, not sure if recent update changed settings.
Tested with another distro via live USB and all 3 monitors are functional, so not sure where things went sideways. I may remove the NVIDIA driver to see if that helps and install the Open driver. If that works will need to evaluate if NVIDIA driver is the issue, If yes perhaps I try an older driver to see the outcome.
If the issue only occurs on the DVI port, then you are not the only one with the problem:
Yes removing and reapplying NVidia driver did not fix. Wondering if I can go to an older driver. If yes I need to figure out how, don’t think there’s a list of drivers using the hardware tool.
Downgrading to NVIDIA 525.xx has fixed my issues. Hoping 560.xx will not be plagued with current bugs
