Deity
30 April 2021 06:52
1
Hi, I'm quite the newbie to linux in general but I've been learning all I can in the last week or so from switching.
I downloaded discord and some games, but whenever discord gives me a message notification it will give my system a quick stutter. This happens in games or even if on youtube or something.
SGS
30 April 2021 09:22
2
Read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
please
and post
inxi -Fxxxza
as text! Even if you personally think it is unnecessary.
and
Deity
12 May 2021 01:40
3
inxi -Fxxxza
System: Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=ed9e35d2-c57b-498a-9b5a-3d3fa8926437
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: ROG MAXIMUS XI HERO (WI-FI) v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 1401 date: 11/26/2019
CPU: Info: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: D (13) microcode: DE cache: L2: 16 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 115200
Speed: 4752 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4752 2: 4790 3: 4703 4: 4736
5: 4700 6: 4181 7: 4702 8: 4650 9: 4770 10: 4700 11: 4700 12: 4701 13: 4760 14: 4702 15: 4700
16: 3844
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Micro-Star MSI driver: nvidia v: 465.27
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1e81 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 4480x1440 s-dpi: 122 s-size: 933x302mm (36.7x11.9") s-diag: 981mm (38.6")
Monitor-1: DP-0 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Monitor-2: DP-2 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 465.27
direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: no
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: efa0
bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 5 TiB used: 27.19 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 2B2QEXE7 scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: RKT30Q.1 scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5425 rpm serial: <filter>
rev: 0001
Partition: ID-1: / raw-size: 465.51 GiB size: 465.51 GiB (100.00%) used: 20.34 GiB (4.4%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:4
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 465.51 GiB size: 465.51 GiB (100.00%) used: 20.34 GiB (4.4%) fs: btrfs
ID-4: /var/log raw-size: 465.51 GiB size: 465.51 GiB (100.00%) used: 20.34 GiB (4.4%) fs: btrfs
ID-5: /var/tmp raw-size: 465.51 GiB size: 465.51 GiB (100.00%) used: 20.34 GiB (4.4%) fs: btrfs
ID-1: swap-1 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
ID-13: swap-13 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram12
ID-14: swap-14 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram13
ID-15: swap-15 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram14
ID-16: swap-16 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram15
Sensors: System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 61 C
Info: Processes: 373 Uptime: 42m wakeups: 1 Memory: 31.27 GiB used: 4.19 GiB (13.4%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1184 lib: 287 Shell: fish
v: 3.2.1 running-in: konsole inxi: 3.3.04
