Disable FPS Counter?
New to linux and i'm finding my way slowly to get things done in linux. Now I have one problem I can't seem to find the solution for. When I start a steam game through proton there is a huge fps counter on the top left and I can't for the life of me figure out how to disable the counter. I don't know wich program displays the counter. I'm on Garuda Linux gaming distro.
Thanks in advance!
Uninstall
mangohud and lib32-mangohud
Thank you so much! I decided not to uninstall because it can be handy sometimes. I do know the keyboard shortcut to disable the HUD temporarily. Opened mangoHUD and checked the options :slight_smile:
Greetings
It was something like ctrl+shift+F12. Or Alt+shift+F12...
on work now,so cannot test...
