Desktop wireless broadcom card no connection found
I just installed Garuda today, and it seemed to be working fine, until I ran a system update, which after a restart broke my wireless. I have spent the last few hours going over several posts and their solutions for similar problems, however nothing seems to work. I have also seen a common solution is to disable random mac addresses, however that didnt do anything. Here is my lspci -k:
    00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD9x0/RX980 Host Bridge (rev 02)
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] RD9x0/RX980 Host Bridge
00:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GFX port 0)
        DeviceName:  Onboard IGD
        Kernel driver in use: pcieport
00:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 0)
00:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 2)
00:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 3)
00:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 5)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] (rev 40)
        Subsystem: ASUSTeK Computer Inc. M5A99X EVO (R1.0) SB950
        Kernel driver in use: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
        Kernel driver in use: ohci-pci
        Kernel modules: ohci_pci
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
        Kernel driver in use: ehci-pci
        Kernel modules: ehci_pci
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller (rev 42)
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller
        Kernel driver in use: piix4_smbus
        Kernel modules: i2c_piix4, sp5100_tco
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA) (rev 40)
        Subsystem: ASUSTeK Computer Inc. Device 86f1
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller (rev 40)
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 PCI to PCI Bridge (rev 40)
00:14.5 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
00:16.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:16.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 3
        Kernel driver in use: k10temp
        Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 4
        Kernel driver in use: fam15h_power
        Kernel modules: fam15h_power
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 5
01:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] (rev a1)
        Subsystem: eVga.com. Corp. Device 6253
        Kernel driver in use: nvidia
        Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
02:00.0 USB controller: ASMedia Technology Inc. ASM1143 USB 3.1 Host Controller
        Subsystem: ASUSTeK Computer Inc. Device 86f2
        Kernel driver in use: xhci_hcd
        Kernel modules: xhci_pci
03:00.0 USB controller: ASMedia Technology Inc. ASM1042A USB 3.0 Host Controller
        Subsystem: ASUSTeK Computer Inc. Device 85bf
04:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
        Subsystem: ASUSTeK Computer Inc. Device 85f0
        Kernel driver in use: igb
        Kernel modules: igb
05:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter (rev 03)
        Subsystem: ASUSTeK Computer Inc. Device 85df
        Kernel modules: bcma
My i3wm work
Which Garuda you use? :smiley: :wink:
and
:slight_smile:
Read wiki
the inxi part, please
Use the snapshot tool and roll back to a working state.
It's likely you picked up an update to kernel 5.10 and that broke the Broadcom wifi driver.
@jonathon is likely correct, a kernel update is most likely the culprit.
I would install linux-lts and linux-lts-headers then reboot. From the advanced Grub boot menu select the LTS kernel to boot into.
Hopefully your wifi will work on the LTS kernel.
If not post your specs:
inxi -Fxxxza
I assume you are using the broadcom-wl-dkms driver. Try uninstalling it then reboot. Once restarted check if your wifi is working using the kernel modules. No luck, then install the wl driver again. Reboot.
I am currently using KDE, I am a bit basic but I may use i3 in the future, I know I am for sure using it for my gentoo install soon
Here is the output of inxi -Fxxxza
  Kernel: 5.10.1-103-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: intel_pstate=passive
  BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq
  root=UUID=4deb08d9-920d-429d-bcb1-5fb0af73cbbd rw [email protected]
  Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Garuda Linux
  Type: Desktop Mobo: ASUSTeK model: 970 PRO GAMING/AURA v: Rev 1.xx
  serial: <filter> UEFI: American Megatrends v: 0701 date: 05/16/2016
  Info: 6-Core model: AMD FX-6300 bits: 64 type: MCP arch: Bulldozer
  family: 15 (21) model-id: 2 stepping: N/A microcode: 6000852
  L2 cache: 2 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 42183
  Speed: 2666 MHz min/max: 1400/3500 MHz boost: disabled
  Core speeds (MHz): 1: 2666 2: 1572 3: 3251 4: 2724 5: 1853 6: 2819
  STIBP: disabled, RSB filling
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: eVga.com.
  driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm
  bus ID: 01:00.0 chip ID: 10de:1c82
  Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: nvidia
  resolution: <missing: xdpyinfo>
  OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2
  v: 4.6.0 NVIDIA 455.45.01 direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 00:14.2 chip ID: 1002:4383
  Device-2: NVIDIA GP107GL High Definition Audio vendor: eVga.com.
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
  Sound Server: ALSA v: k5.10.1-103-tkg-bmq
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
  v: kernel port: d000 bus ID: 04:00.0 chip ID: 8086:1539
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter
  vendor: ASUSTeK driver: N/A modules: bcma port: d000 bus ID: 05:00.0
  chip ID: 14e4:43a0
  Local Storage: total: 2.73 TiB used: 14.79 GiB (0.5%)
  model: WD2003FZEX-00Z4SA0 size: 1.82 TiB block size: physical: 4096 B
  logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1A01
  model: WD10EZEX-00WN4A0 size: 931.51 GiB block size: physical: 4096 B
  ID-1: / raw size: 983.92 GiB size: 983.92 GiB (100.00%)
  used: 14.75 GiB (1.5%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
  ID-2: /boot/efi raw size: 99 MiB size: 95 MiB (95.96%)
  used: 38.7 MiB (40.7%) fs: vfat dev: /dev/sda2 maj-min: 8:2
  ID-3: /home raw size: 983.92 GiB size: 983.92 GiB (100.00%)
  ID-4: /var/log raw size: 983.92 GiB size: 983.92 GiB (100.00%)
  ID-5: /var/tmp raw size: 983.92 GiB size: 983.92 GiB (100.00%)
  ID-1: swap-1 type: zram size: 2.59 GiB used: 0 KiB (0.0%)
  priority: 32767 dev: /dev/zram0
  ID-2: swap-2 type: zram size: 2.59 GiB used: 0 KiB (0.0%)
  priority: 32767 dev: /dev/zram1
  ID-3: swap-3 type: zram size: 2.59 GiB used: 0 KiB (0.0%)
  priority: 32767 dev: /dev/zram2
  ID-4: swap-4 type: zram size: 2.59 GiB used: 0 KiB (0.0%)
  priority: 32767 dev: /dev/zram3
  ID-5: swap-5 type: zram size: 2.59 GiB used: 0 KiB (0.0%)
  priority: 32767 dev: /dev/zram4
  ID-6: swap-6 type: zram size: 2.59 GiB used: 0 KiB (0.0%)
  priority: 32767 dev: /dev/zram5
  ID-7: swap-7 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
  priority: 1024 dev: /dev/sdb3 maj-min: 8:19
  System Temperatures: cpu: 17.2 C mobo: N/A gpu: nvidia temp: 31 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
  Processes: 237 Uptime: 10h 43m wakeups: 0 Memory: 15.53 GiB
  used: 3.14 GiB (20.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  Packages: pacman: 1073 lib: 272 Shell: fish v: 3.1.2 running in: konsole
  inxi: 3.2.01
I already have reinstalled thebroadcom-wl-dkms driver, and I have decided it is probably time to upgrade my card anyway (it is many years old) so I am getting an intel one in off amazon tomorrow. I would still like to fix this issue, however, because it will ensure I have a working card if the intel one has issues or doesn't work, also, I was refraining from downgrading my kernel to a lts, mainly because I like to be "bleeding edge" of whatever distro I am on, but I will try that if all else fails. Thank you guys for the really quick support! I fell asleep for a bit so I am a bit late to reply.
Then you could try the linux or linux-mainline kernels (and headers).
@tbg ah, I think I will do that then. I just need to boot into the garuda snapshots tool, right? I am a bit of a newbie to some of this stuff
sudo pacman -S linux linux-headers
sudo pacman -S linux-mainline linux-mainline-headers
Reboot.
Swap kernels at grub advanced boot menu.
Ah, okay thank you so much! I will post if this works or not!
The mainline kernel did not change the issue at all, with there being no connections found
Try the others then.
currently working on that, I might give up until tomorrow when my new card comes in
This seems to have fixed my problem with wireless on the Apple Macbook Pro 11.4 I run. Nothing else I tried had worked. Thanks for the post.
