Not on my Laptop, try resetting latte with garuda-assistant
, if you change something on latte dock.
I reset latte with the assistant and re-booted but the Latte Dock still jumps in with every wallpaper change.
It may be worth trying if this still happens with the git package latte-dock-git
(uninstall latte-dock first), in the past I have had issues with latte-dock that were fixed in the -git package.
Also, maybe try uninstalling tlp
if that is installed on your system.
I switched to the latte-dock-git but the probkem still remains. It is OK, I can easily live with it.
However, I now get the message -
Authentication is needed to run /usr/bin/env as the super user
Vendor = The polkit project
Should I enter my password and let it continue ?
Many thanks.
