For the last few days my desktop settings, especially wallpaper, keep resetting. (Weyland and Xorg) This results in a black screen on login. I can set the wallpaper, but it reset again on the next boot.
I looked into the plasma-desktop-appletrc but could not find anything that was helpful. Where and how can I reset the plasma desktop settings permanently?
Garuda-inxi
Kernel: 5.19.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a30a23e0-d074-433e-acb9-8d13aa66a683 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_wayland vt: 2
Type: Laptop System: Dell product: Inspiron 5415 v: 1.2.0
serial: <superuser required> Chassis: type: 10 v: 1.2.0
Mobo: Dell model: 0FH5FM v: A00 serial: <superuser required> UEFI: Dell
v: 1.2.0 date: 05/13/2021
ID-1: BAT0 charge: 40.5 Wh (76.7%) condition: 52.8/54.0 Wh (97.8%)
volts: 16.9 min: 15.0 model: SMP-ATL3.66 DELL XDY9K15 type: Li-poly
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1986 high: 2708 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2100 2: 2708
3: 2100 4: 1445 5: 2100 6: 2100 7: 2377 8: 1397 9: 1427 10: 2100 11: 1879
12: 2100 bogomips: 50304
protection
Device-1: AMD Lucienne vendor: Dell driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 0c45:6a10 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
alternate: fbdev,vesa gpu: amdgpu display-ID: 0
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.12-zen1-1-zen)
v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Dell
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
Device-3: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.19.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.58 running: yes
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-2.1:3 chip-ID: 0bda:8153 class-ID: 0000
IF: enp3s0f3u2u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 3-3:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 238.47 GiB used: 187.17 GiB (78.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
rev: 21112012 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 43.95 GiB size: 43.95 GiB (100.00%) used: 35.62 GiB
(81.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 616 KiB
ID-3: /home raw-size: 185.43 GiB size: 185.43 GiB (100.00%) used: 151.55
GiB (81.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 43.95 GiB size: 43.95 GiB (100.00%) used: 35.62
GiB (81.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 43.95 GiB size: 43.95 GiB (100.00%) used: 35.62
ID-1: swap-1 type: zram size: 14.98 GiB used: 2.8 MiB (0.0%)
System Temperatures: cpu: 34.0 C mobo: 29.0 C gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): cpu: 0
Processes: 333 Uptime: 1h 17m wakeups: 151 Memory: 14.98 GiB used: 3.89 GiB
(26.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1732
libs: 390 tools: octopi,paru,yay pm: flatpak pkgs: 0 Shell: fish v: 3.5.1
running-in: alacritty inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-01-31
Last full system update: 2022-10-01
Failed units: intel-undervolt.service
