So this happened. I was switching my GPU with optimus-manager, like I do every day, but it got hanged so I had to force reboot. After the reboot Garuda booted up, but the desktop loaded without any of my settings, without any background image, panel located in the bottom like in default KDE, all of my passwords are forgotton, including my wifi password.
I tried using snapshots, booting with the LTS kernel, all that jazz, but that didn't help. I tried running update on terminal and got a message that system was only partially updated. I tried running update again, everything went well and I rebooted. Didn't fix the problem.
I'm going to set it all up again, a bit of a chore.
Here is my inxi -Faz (after I updated):
LANGUAGE = "en_GB:en_US:fi:pt_BR",
LC_ALL = (unset),
LC_ADDRESS = "fi_FI.UTF-8",
LC_COLLATE = "fi_FI.UTF-8",
LC_CTYPE = "fi_FI.UTF-8",
LC_IDENTIFICATION = "fi_FI.UTF-8",
LC_MEASUREMENT = "fi_FI.UTF-8",
LC_MONETARY = "fi_FI.UTF-8",
LC_NAME = "fi_FI.UTF-8",
LC_NUMERIC = "fi_FI.UTF-8",
LC_PAPER = "fi_FI.UTF-8",
LC_TELEPHONE = "fi_FI.UTF-8",
LC_TIME = "fi_FI.UTF-8",
LANG = "en_FI.UTF-8"
perl: warning: Falling back to the standard locale ("C").
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=33b92acc-eae1-4daf-86a1-a400c31bc857 rw
rootflags=subvol=@ splash intel_iommu=on rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASRock model: Z370 Gaming-ITX/ac serial: <superuser required> UEFI: American Megatrends
v: P4.30 date: 11/01/2019
Battery: Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: EA cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 88796
Speed: 4435 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4435 2: 4464 3: 4600 4: 4600 5: 4292 6: 4461 7: 4248
8: 4601 9: 4600 10: 4600 11: 4600 12: 4602
Graphics: Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: ASRock driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia v: 470.62.02
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0") s-diag: 987mm (38.8")
Monitor-1: DP-1-3 res: 3440x1440 dpi: 107 size: 819x346mm (32.2x13.6") diag: 889mm (35")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 470.62.02 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: SteelSeries ApS Arctis Pro Wireless type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.3:6
chip-ID: 1038:1297 class-ID: 0300
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6
chip-ID: 8086:15b8 class-ID: 0200
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple driver: wl v: kernel modules: bcma
bus-ID: 04:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp4s0 state: dormant mac: <filter>
Bluetooth: Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8 bus-ID: 1-14.3:11 chip-ID: 05ac:828f
class-ID: fe01
Drives: Local Storage: total: 2.56 TiB used: 2.27 TiB (89.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: R0906I temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800 size: 1.86 TiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 7A
Partition: ID-1: / raw-size: 39.26 GiB size: 39.26 GiB (100.00%) used: 31.76 GiB (80.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 560 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 437.18 GiB size: 437.18 GiB (100.00%) used: 379.87 GiB (86.9%) fs: btrfs dev: /dev/nvme0n1p3
maj-min: 259:3
ID-4: /var/log raw-size: 39.26 GiB size: 39.26 GiB (100.00%) used: 31.76 GiB (80.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw-size: 39.26 GiB size: 39.26 GiB (100.00%) used: 31.76 GiB (80.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.03 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 43%
Info: Processes: 391 Uptime: 6m wakeups: 2 Memory: 31.03 GiB used: 5.73 GiB (18.5%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: note: see --pkg pacman: 1781 lib: 557 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.09
