Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=39af5c4a-2f35-43de-bb0c-e0d4be82b476 rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: Hewlett-Packard product: HP EliteBook 840 G1
v: A3009DD10203 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 198F v: KBC Version 15.59
serial: <superuser required> BIOS: Hewlett-Packard v: L71 Ver. 01.47
date: 04/18/2019
ID-1: BAT0 charge: 18.9 Wh (85.5%) condition: 22.1/22.1 Wh (100.0%)
volts: 13.0 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i5-4300U bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 high: 800 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 798 4: 800
bogomips: 19953
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: AMD Mars [Radeon HD 8730M] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 2
speed: 5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 8 ports:
active: none empty: DP-3,DP-4 bus-ID: 03:00.0 chip-ID: 1002:6601
class-ID: 0300 temp: 46.0 C
Device-3: Chicony HP HD Webcam type: USB driver: uvcvideo bus-ID: 2-7:5
chip-ID: 04f2:b3ed class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: crocus,radeonsi gpu: i915 display-ID: :0
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 model: Samsung 0x484e built: 2012 res: 1600x900 hz: 60
dpi: 132 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1600x900
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 4400 (HSW
GT2) direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
Device-3: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 8
bus-ID: 03:00.1 chip-ID: 1002:aab0 class-ID: 0403
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: 4080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
bus-ID: 2-3.2:4 chip-ID: 8087:07dc class-ID: e001
address: <filter>
Local Storage: total: 465.76 GiB used: 130.14 GiB (27.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD050V
type: HDD rpm: 5400 serial: <filter> rev: 1Q scheme: MBR
ID-1: / raw-size: 265.44 GiB size: 265.44 GiB (100.00%)
used: 130.14 GiB (49.0%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /home raw-size: 265.44 GiB size: 265.44 GiB (100.00%)
ID-3: /var/log raw-size: 265.44 GiB size: 265.44 GiB (100.00%)
ID-4: /var/tmp raw-size: 265.44 GiB size: 265.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.73 GiB used: 503.5 MiB (13.2%)
System Temperatures: cpu: 49.0 C mobo: N/A gpu: radeon temp: 46.0 C
Processes: 199 Uptime: 17m wakeups: 1 Memory: 3.73 GiB
used: 2.35 GiB (63.0%) Init: systemd v: 252 default: graphical
pkgs: 1399 libs: 415 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-12-11
Last full system update: 2022-12-28
I tried to update my system on 14.01.2023, and after rebooting, the flash screen and login screens worked okay, but on the desktop only the sticky note widget and application icons would load and would blink in and out every few seconds leaving a black screen. I managed to restore by using the pre-update snapshot, but I tried updating again today and the issue reoccured. Does anyone know what's going on and how to fix it?
