Hi guys!
inxi -Faz
System: Kernel: 5.14.6-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d79dfe17-6443-4139-8ade-59a1d507c8b5 rw
rootflags=subvol=@ splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
loglevel=3 mitigations=off sysrq_always_enabled=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: Micro-Star model: B560M PRO-VDH (MS-7D18) v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: 1.00 date: 03/01/2021
CPU: Info: 6-Core model: 11th Gen Intel Core i5-11500 bits: 64 type: MT MCP arch: Rocket Lake family: 6
model-id: A7 (167) stepping: 1 microcode: 40 cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 65088
Speed: 4573 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 4573 2: 4542 3: 4595 4: 4571 5: 4569 6: 4600 7: 4600
8: 4548 9: 4341 10: 4559 11: 4600 12: 4600
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and usercopy barriers only; no swapgs barriers
Graphics: Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:4c8a class-ID: 0300
Device-2: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3:2 chip-ID: 046d:082b
class-ID: 0102
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5") s-diag: 1165mm (45.9")
Monitor-1: HDMI1 res: 3840x2160 hz: 60 dpi: 155 size: 630x360mm (24.8x14.2") diag: 726mm (28.6")
OpenGL: renderer: Mesa Intel Graphics (RKL GT1) v: 4.6 Mesa 21.2.2 direct render: Yes
Audio: Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
class-ID: 0102
Sound Server-1: ALSA v: k5.14.6-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: no
Network: Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Drives: Local Storage: total: 494.82 GiB used: 32 GiB (6.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7 temp: 38.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Glide 3.0 size: 29.06 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 32 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 32 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 32 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 32 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.45 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 27.8 C mobo: N/A
Info: Processes: 294 Uptime: 1m wakeups: 0 Memory: 15.45 GiB used: 2.07 GiB (13.4%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1665 lib: 502 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
I have an issue with Garuda.
I had made a big blunder and wrote in console 'sudo rm -r /var/lib/pacman/db.lck' and then my dekstop stoped working and all of my backups have been deleted.
I booted my computer again and then even live version was working bad: wallpaper after clicking became black, settings didn't work: i can't see what i am clicking on - some kind of freeze but i can change settings, latte doesn't work too and windows of applications seems to be broken - blinking fast and it is not possible to click anywhere.
If it is needed I pin journalctl log from starting of system.
I tried already reset settings in garuda assistance, updating system.
This is my first post and I am writing it because I couldn't find any answer to this, if this is simillar to other posts, sorry but I really gave up in searching.
And lastly I want to admit that you guys are making a really great job. This is amazing how configurable from GUI level this system is, how it feels using it and how this community and your team works. Great job guys.
